HELP! block is leaking water?
Discussion in 'The Garage' started by 82K5_6.5L, Apr 22, 2007.
  1. 82K5_6.5L
    82K5_6.5L 1/2 ton status
    Dec 4, 2002
    439
    Tucson, Az
    i go to top off the radiator 2nite and i hear this drip...drip..drip and then its almost like a flood! seems the leak is coming right close to the water pump area (btw motor is a 6.5l) any ideas of y this could be happening?? :confused:
  2. Disturban
    Disturban 1/2 ton status
    Mar 9, 2006
    120
    Phx,Az
    When water pumps go out, water comes out of a small hole in the back...chk the pump good,hopefully that's it.
  3. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    can you explain that a bit more? i think i'm having the same issue, but i don't over heat, the pump turns freely, and the temp is a constant.
  4. tRustyK5
    Jul 23, 2000
    36,166
    1,363
    E-town baby!
    There is a weep hole on the underside of the water pump. When the seal goes bad coolant will begin to drip from there...eventually coolant will gush out of that hole when the seal gets bad enough.
    Rene
  5. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    which seal are we talking about? i just did a whole timing cover set.
  6. Bow-Tie-Boy
    Bow-Tie-Boy Registered Member
    Feb 14, 2005
    71
    Ft. Hood, Texas
    The seal he is talking about is inside the water pump. If that's where it is coming from, then all you have to do is replace the water pump.
  7. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    Look on the underside of the nose of the water pump- you will see a small hole in the casting. That is where it will begin to leak from when the INTERNAL seal goes bad.
