HELP!!(brake problems)
Discussion in 'The Garage' started by jfabert, Aug 29, 2005.
  1. jfabert
    jfabert 1/2 ton status Premium Member
    Dec 1, 2004
    161
    South Ogden, Utah
    Ok, my rear brakes have never worked very well sence I have had the truck. They dont have much stopping power. Front worked great, I had to replace the front pads and after that the brakes dont work as well as before I replaced them. After that I have replaced the master cilinder, distribution block 2x, all the springs, adjusters and shoes in the rear and blead the hell outa them. Now they work even worse. The more work I do on them they seem to get worse. What should I do. Im going to order up a set of braded brake lines next sence they do need replaced also. Its an 87 k5 by the way. Could it be my booster sence that is about all I havent replaced?
  2. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    All The Booster Does Is Assist You In Pressing The Brake Pedal (more Or Less). Have You Adjusted The Rear Brakes? If They Are Not Properly Adjusted The Cylinder Have To Much Travel And The Pedal Will Pretty Much Go Almost To The Floor.
  3. jfabert
    Dec 1, 2004
    161
    South Ogden, Utah
    I did when I replaced every thing. My pedal has alwase almost gone to the floor. After I replaced everything the e-brake dont have as much power eather as before. Maybe I am doing it wrong. I adjust them out until they have a little bit of contact with the drum, right?
  4. dyeager535
    26,977
    The way I adjust my rears is turn the adjuster until I can't fit the drum on, then back it off until I can. That works every time for me.
    The e-brake cable adjustment is seperate of the actual fluid portion of the braking system, you tighten up the cable to make it hold better. (obviously the ebrake shares the same hardware as the fluid portion of the brakes)
  5. jfabert
    Dec 1, 2004
    161
    South Ogden, Utah
    Thats basically the way I do it when adjusting them. I was looking at the e-brake cables and thought the way to adjust it was where the two cables come together just in front of the rear drivers tire, the cable for the passanger side has a bold on the end. Is this the spot to tighten it up at? My other truck is a 82 so a few of the brake parts are alittle difrent so im not use to this one yet.
  6. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    i agree. ure e-brake not working well is a sign that it out of adjustment. has nothing to do with fliud. u can adjust them through the back till u hear and feel them rubbing. that will also make brakes go to floor more then they should.
    dumb q, when u bled brakes, did u clean the sludge out of the bottom of resevoir? and didnt suck any air in? sorry had to ask
  7. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    no has to adjusted in the drum first
  8. jfabert
    Dec 1, 2004
    161
    South Ogden, Utah
    I put a new master brake cilinder in. Bench bled it before and have bled them after I installed it. (no sludge) Have bled them another time after that when I replaced both wheel cilinders, Forgot to add them to my list or replaced parts.
  9. jfabert
    Dec 1, 2004
    161
    South Ogden, Utah
    Anyone have some more ideas. Could it be the 35" tires too and the drums just dont have enough to stop them easly? I need some help cause I need to have them fixed before winter so I wont have to park it during the winter.
  10. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    did u try adjusting the brake from the drum? u can acess it from pulling the oval boot off of back plate and use screwdriver to push th3e cog so brakes are snug
  11. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    btw, mine is stock and original im sure, i have 35's and i stop fast. back gets a little squirrelly though.
    i take my pads off every so often (usually after muddin) and clean out riviots and sandpaper pads and drum/disk. keeps em effecient IMO
  12. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    have u tried backing up and pumping brakes? that is how they norm. adj. but if they are way out they wont adj well
  13. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    when your adjusting the adjuster on the drums, you want to tighten it all the way out with the drum on so you know the shoes are centered and back them off so you hear just a little scraping sound. you will need a long skinny object to push the clicker thing back off the adjuster so you will be able to turn it back. also, if you have new shoes, you need to make sure your drums are smooth tlike glass or get them turned and make sure you brake them in properly for best performance.
  14. jfabert
    Dec 1, 2004
    161
    South Ogden, Utah
    Mine dont have the hole punched out in the backing plate. Im going to do this because when I got new adjuster hardware they came with the plugs for it. Maybe Ill get them turned because I have a little lip on the edge of the drum so I have to have the shoes pulled in a little to get the drum on.
  15. jfabert
    Dec 1, 2004
    161
    South Ogden, Utah
    Yea I have done that, about half a mile trying to see if it would help, and it didnt do much.
  16. jfabert
    Dec 1, 2004
    161
    South Ogden, Utah
    Brake them in?? How should one do that?
  17. PsychoticDeadGuy
    Jan 8, 2005
    753
    get up to about 15-20 mph and slowly apply brakes...25-30 and slowly brake...do this in incremints and let your brakes cool enough so they actually seat good. dont just go you and do 100mph and slam on your brakes. i havent really had much of a problem with lifted trucks and not braking them in its mostly stock size tires and a smooth drivetrain that you can tell. even if you dont brake them in properly they will end up being fine. i just work with quite a few street racer cars that need to be able to run from the peeps that are chasing them if there driving illegaly...such as 5.0 mustangs and camaros and maybe a few imports.
  18. jfabert
    Dec 1, 2004
    161
    South Ogden, Utah
    Thanx everyone for the help! I think I need to take it to a shop and have them power blead them hopefully that will do it sence I have replaced EVERYTHING!
