Help - Brakes/Rim Size Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ryeguy, Feb 26, 2001.
  1. Ryeguy
    Ryeguy 1/2 ton status
    Oct 30, 2000
    Victoria, B.C.
    Hi guys,
    I've got an '87 K5 in the process of being built, extremely
    modified. This should be an easy question for right right
    - 6-bolt 15-inch rims fit on the stock 10-bolt front diff, but
    there isn't much room for clearance between the caliper
    and the rim
    - after grinding the calipers, 8-bolt 15-inch rims will fit over
    1-ton brakes (D60 stuff), and there's even less clearance
    - can the same procedure be used to fit 15" rims over 8-bolt
    3/4-ton brakes?
    - the light-duty 3/4-ton brakes use the same caliper as the
    half-ton, I'm more interested in using the larger piston heavy
    duty 3/4-ton brakes, can this be done? Or do I have to stay
    with the small 6-bolt rim pattern to use the heavy-duty 3/4-
    ton calipers? (I'd like to convert to HD 3/4-ton brakes).
    Why? The 3/4-ton brakes use the GM 2 bolt style mounting,
    where the D60 uses the Bendix style caliper mount which will
    be a lot harder for me to work with for my project. And I'll
    need a bigger caliper than the stock half-ton caliper to stop
    this beast.
