help! breather tube on 14b gone!
Discussion in 'The Garage' started by muddybuddy, Feb 20, 2006.
  1. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    so i went to go hook up the rubber breather hose on my 14b, when i noticed it didnt look good, i touched it and most of it fell off....if this was jus a plain 14b, or if i did rocks only i would be concerned, but i have pretty much rebult the whole thing and put in a detroit and new gears, and do mostly mud....what can i do??? help me please.
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    drill and tap the hole for a hose barb and you should be fine
  3. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    ive already got a tap and die set so thats taken care of, can i just get a factory hose barb from the auto parts store?
  4. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    just buy a NPT hose barb from a hardware store and you will need a NPT tap you probley only have standard thread taps
  5. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    you will need a pipe thread tap for the hose barb, i don't think an auto parts store is gonna have it, gonna have to go to a hardware store.
  6. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    so sears should have it right? i gatta go there anyway to pick up a 1.5" socket for the pinion nut. any idea what size pipe thread im gona need?
  7. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    i got all i needed at napa
  8. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    thanks ill check it out
  9. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    pipe size depends on tap size. 1/4" npt should suffice but you might need to step up to 3/8" npt. All depends on the size of the hole thats there. also what size fitting you can get your hands on. A 1/4" npt x 3/8" barb or 3/8" barb x3/8" npt will work fine
  10. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    thanks, ill get on it!
    ill have fun doin it while its under the truck :-)
  11. GotLabs
    GotLabs 1/2 ton status GMOTM Winner
    Jul 30, 2005
    2,795
    Transient, USA
    I would just jb weld a fitting into the hole.
  12. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    rember the old trick
    if you load the tap up with grease, and go slow, load tap clean, load tap clean
    you can do it with out pulling the cover or getting any tap shavings in the housing
    thats what i did
  13. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    i bought one of those.. what do you call its..... hmmmmm
    wanna call it a barrel or something like that... like a tube with a slit down the entire thing.... just tapped it down into the hole... put my vent hose down the rest of the way to the axle and hose clamped it... works fine and cost me $.32 :crazy:
  14. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    I call it a roll pin. Just be sure you fill the gap left over with some sealer.
  15. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    im not quite sure exactly what your talkin about, but ill check it out.
    whats the best way to get the old one out? by drilling? it broke off, so part of it is still in there.
