HELP! broken car lift!
Discussion in 'The Lounge' started by supersize75k5, Sep 3, 2006.
  1. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    my blazer...which I need to install a sm465 and 205 in is currently stuck on a car lift!
    the ram went out and is leaking bad, wont go up or down !:mad:
    the ram has a plug near the top, about 7/16 large with a allen head hole in it, its leaking from the middle,
    this really sucks!
    I dont know much about rams,
    looks like I have to pull the ram out, do I neet to lift the truck some how and lower this? or can I do it with the truck on there? has large chains, similar to a fork lift design.
    any imput or any one with advice? I dont want to get hurt trying to lower a truck off a broke lift in an unsafe mannor:crazy:
  2. BIG*RED
    BIG*RED 1/2 ton status
    Mar 14, 2003
    1,094
    take pics!
  3. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Call the company that made it
  4. sweetk30
    Nov 1, 2004
    25,539
    539
    horseheads , ny 14845
    DONT OPEN THAT PORT.
    that will let all the fluid out and drop 1 side. you need to find a way to lift up that side and undo the safty latch and pring the rig down in a safe way. it might not be easy but take your time as a uncontroled drop could also bend your frame from switching load positions on it setting there.
  5. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    ignore the cage, its just sitting on the wheel wells..not in place
    the last pic is from todays wheeling... just had to throw it in there :)
    I wish I could post the other pics..but they cant even be posted in the pig pin!...deep water..mud..skirts..and tops that had trouble staying on! Im in no hurry to get old!
  6. ssped
    ssped 1/2 ton status GMOTM Winner
    Jan 5, 2006
    1,529
    Mission Viejo
    can you refill the external reservoir with fluid? if it is low it will not lift.
  7. draggbody
    draggbody 1/2 ton status
    Jul 13, 2005
    282
    columbus GA
    you could always post them to jimmy@columbuscustomexhaust.com ... seriously does the lift have two rams or just one??? if one, how high is it off the ground??? what i mean is the bottom of the arms for the lift...
  8. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Send a copy of those pic's to me! Did you get the truck down then?
  9. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    the truck is still up there!
    the lift has two rams,
    also..wouldn't filling the resivoir just allow it to leak more fluid?:crazy:
    the arms are about 3 or 4 feet off the ground.
  10. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    can you find 4 big jackstands to support the truck then bleed the cylinders off?
  11. ssped
    Jan 5, 2006
    1,529
    Mission Viejo
    if you ran it low on fluid and unless it is just straight pouring out of the hole(in which I would say tap it and stick a brass plug in it.) refilling it will allow you to raise it up and unlock the rack to lower it. that will work if it is a small leak if it is a big leak tap it and plug it.
  12. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    it leaked alot of fluid..
    how would I fill the ram back up? when I have the plug out to tap it?
    I *believe* 99 percent it is on the locks,
  13. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    could the seal have blown near the piston?
    thuus allowing the fluid to leak out of there?
  14. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    got it out of there...
    the ram that is.
    easy as pie!
    undid the line from the bottom, undid a fitting or two, took off the chain and out she came...
    ill be droping it off to get rebuilt tomarow..I am really...really glad I didnt have to call a mobil repair for this...very easy once it was figured out:crazy:
  15. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    It's not really a seal on hydraulic cylinders but rather it's a packing. Usually consisting of a larger rubber seal along with multiple o-rings. Yes they can fail, usually it's caused by a foreign object which can also score the chrome on the shaft.
  16. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    hey what the hell is this doing in the lounge?
    aahahhahaahah tech!!!!!!
  17. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
  18. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    of what?
    :D
    the lift?
  19. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,859
    282
    Truckee, CA
    you are a lucky bastard.
  20. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Of these pics you speak of.
