Help! broken sparkplug
Discussion in 'The Garage' started by JeremyK5, Dec 17, 2003.
  1. JeremyK5
    JeremyK5 1/2 ton status Premium Member
    Aug 12, 2001
    549
    Indiana
    I was changing the sparkplugs on a friend's 92 GMC fullsize van with a 4.3L v6 and the hex shaped part of the sparkplug snapped off, leaving the threaded part still in the head. /forums/images/graemlins/1zhelp.gif Of course it's the driver's side front sparkplug, which is the hardest to reach from inside the van.
    Anybody have any ideas, or am I gonna have to figure out how to pull the head with the firewall in the way, and take it to a machine shop? /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
    It seems to run ok with that clyinder puffing air in and out, but I need to figure out something soon! /forums/images/graemlins/ears.gif
  2. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    Have you tried an EZ-out yet? If you do make sure the piston is not at the top of the cylinder and also use the largest square kind you can fit and be very careful while trying to remove it so as not to break the EZ-out.
  3. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    My buddy did that not to long ago and he had to pull the head and have it drilled out
    nick
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yep we had it happen on an 88 or so ford dinky hatchback car with tiny 4 cyl in it and we had to take head off and have it surgically removed at a shop
    should always coat tthreads with anti sieze or something else good, this is one of those rare things that happens, and it probably wont happen to you again, unless maybe you work on a billion engines and stuff for yourself or others. i dont think ill come across this one again, i doubt it.
    at least for you it happened to a GM 90 degree engine and not a japanese 4 cyl /forums/images/graemlins/frown.gif it was no fun,.
    good luck
  5. MarcS
    MarcS 1/2 ton status
    Oct 4, 2002
    515
    NJ
    Before you remove the head, did you try heating it up and then try an EZ-out ? Not sure if the heads aluminum so be careful with the heat. I would try everything before disassembly.
  6. dyeager535
    26,979
    That's a good point. I've known people that had problems removing exhaust manifold to head bolts, and warming up the engine loosened things up enough to get them free.
    It certainly can't hurt to try, it's free.
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I have had it happen and got it out with an ez out and pb blaster. Thank God it was on the stand.
  8. JeremyK5
    Aug 12, 2001
    549
    Indiana
    After looking at it some more, I'm pretty sure I'm gonna have to pull the head, since it's a van. The firewall and floor are too close to the head, there really isn't any room for a drill in there for an ez out. /forums/images/graemlins/frown.gif
