Help! Cam and intake install
Discussion in 'The Garage' started by camokrawler, Apr 11, 2006.
  1. camokrawler
    camokrawler Registered Member
    Mar 2, 2006
    47
    Central North Carolina
    Can some give me a run down of where i need to put RTV silicone when put a cam and intake in? The felpro rubber gaskets said no rtv. but what about timing chain cover/front of oil pan, intake gaskets, etc. Any input appriciated or tips and advice in general. Thanks guys
    camokrawler
  2. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    the only place we put rtv is on the front and back of the block where the intake sites.. that is it..... and no leaks...:wink1:
  3. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    I use it on the timing cover too.
  4. detailer03
    detailer03 1/2 ton status
    Sep 23, 2003
    108
    Arizona
    if you have a gasket, you really do not need rtv. I only use it to hold the gasket in place.
    Also for the intake in front and rear.
