help... cant find longer steering arm studs locally..
Discussion in 'The Garage' started by leadfoot067, Oct 1, 2002.
  1. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    i have crossover on a d44..did the one inch zero rates now the drag link hits the springs when i turn left.....so i made a 1" block to put under the steering arm and cant find longer 9/16x18 studs..they need to be 4 inches long ....any suggestions????
  2. bad_bo_ti
    bad_bo_ti 1/2 ton status
    1,027
    OhiO
    try superlift or anyother lift company thats sells the arm lift blocks, they should have install kits.
  3. leadfoot067
    May 14, 2001
    1,563
    ya but those lift blocks are 3 or 4 inches according to the catalogs,and my block is only 1"..they would be too long
  4. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    can they be cut down? the longer ones? from superlift...
  5. leadfoot067
    May 14, 2001
    1,563
    i dunno they are 2 inches longer than what i need..i bought some grade 8 bolts today...talked to a couple friends and they should be fine
