Help Cant get E-Brake to release
Discussion in 'The Garage' started by CaveBlazin, Sep 21, 2002.
  1. CaveBlazin
    CaveBlazin 1/2 ton status Premium Member
    May 21, 2002
    1,348
    Middle TN
    Ok so my ride has been bed riden for the last month and now I got her up and runnin again but the problem is she wont get running with out the emergency brake to release. Whats the best way should I floor it and see if it pops out Ive pressed and released it about a 1000 times any suggestions before I break something (whats new)
  2. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
    get underneith the truck down by the rear axle and look at the cable on the drivers side, where it splits to two. at that point there is a metal bar that makes them work together, if one cable is farther forward than the other and the bar is also leaning, tug on the one that is the farthest forward. that will be your stuck one. usually it will come undone with a slight tug, or even a tap on hte metal bar where the cables split.
    good luck
    ~~~jeff
  3. CaveBlazin
    May 21, 2002
    1,348
    Middle TN
    I just remembered exactly what you just said I forgot this happened once before now its loose and moving. Thanks for the mind refreshing. LOL
