help...changed boot.ini file****EDIT*** Fixed
Discussion in 'The Lounge' started by randy88k5, Apr 30, 2005.
  1. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    Fixed Prolem, thanks anyway.
  2. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    Lobster!
  3. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    I don't think your system is even reading boot.ini. Either way, before messing with it, make a backup copy of it...
    If you can boot to dos (win98 startup disk), at the command prompt, type "Fdisk /mbr" and hit enter, then reboot and see what happens. That will restore your master boot record to hopefully point to the boot.ini (there's a chance it will point directly to win98).
    Unless you encrypted the ntfs drives without saving a backup key, they shouldn't be lost. Absolute worst case, you can reinstall winxp over the top and regain access to them (unless they're encrypted, which I dount, then you're possibly screwed if you can't get back into the current install of XP).
