help changing hubs!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Confederate9, Dec 25, 2001.
  1. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    hey guys, for xmas i got some warn premium hubs for my stock font axle, and i have no clue how to take out my autos and put the new ones in, can someone give me some directions?
    thanks
    <font color=red>K5: Because size DOES matter</font color=red>
    85 K5 4IN LIFT 35 GOOD YEAR WRANGLER MT/R, AMERICAN RACING WHEELS
  2. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    It's been afew years but ill ty to jog the old grey matter. You remove the cover, and inside will be the hub. Holding the hub in place is a c clip that is attached to the end of the axle. Remove that c clip and the hub will come out. When you install the new hub do NOT replace that c clip, use the big round snap ring instead. Hope this helps. I'm sure someone else will fill in all my blanks!
    That jeep thing? Yah I understand it....... Like my Blazer? <a target="_blank" href=http://community.webshots.com/user/blazerk5>http://community.webshots.com/user/blazerk5</a>
    Jim
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Take the 5 bolts out, pull off the cap, Remove the retaining clip on the axle shaft as said in above post.
    There is also a large retaining ring that goes around the inner diamiater of the hub. You will see a little metal cover on the outside edge of the auto hub assembly. Pull this cover off. behind it you will see two pins. Squeeze them togeather with a pair of needle nose(this compresses the retaining ring) and pull the auto assenbly should pull right out.. If it doesn't want to come out thread a couple of the bolts back in and use them to pull on. Thats is about it.
    Put the new hubs in according to the instructions
    <a target="_blank" href=http://coloradok5.com/gallery/Thunders-Blaze> Blazer pics</a>
  4. Rob 85K5
    Rob 85K5 1/2 ton status GMOTM Winner
    1,487
    Pensacola, Florida
    <a target="_blank" href=http://community.webshots.com/photo/16907259/16907402zHYyFoAnhM>This</a> may help give you an idea what you're looking at.
    Rob
    <font color=orange>Bleedin' Chevy Orange</font color=orange>
