HELP! chipped pinion!!!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by The85k5, Feb 4, 2002.
  1. The85k5
    The85k5 1/2 ton status
    Feb 22, 2001
    259
    Sunnyvale,Ca
    well about a month ago a picked up a 12 bolt 4:10 axle to replace my 10 bolt 3:08....today i finally took the cover off to find out one of the teeth on the pinion gear had about 1/4 or more of it missing! should i say screw it and drive it till it breaks or take the damn thing apart? anyone have a spare pinion they wanna give me?
    All terrains dont do well in mud
    Robb
    Newark,Ca
  2. The85k5
    Feb 22, 2001
    259
    Sunnyvale,Ca
    top
    Robb
    Newark,Ca
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I've seen people drive for years on that kinda stuff and have no problems. That kinda sucks. Is it a daily driver?
    If not I would just drive it and check the pan for more chunks often. You can always take off your driveshaft and drive home on the front (if you have a fixed yoke or a plug for the rear).
    If it is a daily driver I would have it repalced.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
