help choose a muffler
Discussion in 'The Garage' started by az ranger, Jan 22, 2006.
  1. az ranger
    az ranger 1/2 ton status
    May 9, 2004
    139
    Safford AZ
    I need to quiet my exhuast, currently I have stock manifolds that collect into a single three inch flowmaster (model unknown) that dums down after the axle, also I have no cat.
    I cant handle the constant noise. I would like to still hear it a little when I get in it but just not so loud. I am thinking of getting the flowmaster 70 series but they are so big and cost a lot.
    what else should I be looking at.
    BTW mine is a multi purpose rig seeing a little of everything
  2. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    I personaly have a Series 50 muffler. I LOVE how it sounds. under acceleration it sounds great and if you realy get on it... Well I like it. at idle you can hear it but just cruisin its actually pretty quiet.
    I run 2 1/4 pipe into the muffler then a 3" out dumping in front of my Lf Rear tire.
    Tomorrow i can post a sound thing if you want. Its 9 right now and probaly wouldnt be the best time to do a Muffler uhh Sound clip i guess lol
  3. sweetk30
    Nov 1, 2004
    25,540
    539
    horseheads , ny 14845
    where is the muffler mounted? if under the cab then move it past the back of the cab. this will be better as it wont resinate under the floor. and also get it to dump out a actual pipe from under the body as this will make it sound louder. my friend has the same truck as me and same exaust with same mufflers. his is just dumps from mufflers to under the box. and it is much louder than mine that exits the sides of my box at the rear.
  4. az ranger
    May 9, 2004
    139
    Safford AZ
    I should have mentioned that I have a blazer and not a truck. My muffler is mounted in front of the rear axle it then has about 1/1/2 ft of 3 in pipe that dumps out behind the rear axle on the drivers side. I plan to exit it out the side after I put on new muffler to help with sound thanks for the replies keep em coming
  5. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    you dont need a new muffler... move it back a little, run the exhaust up over the axle, and exit it out the side. you should be good then.
  6. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    i just put a set of super 40's on my truck, i had original 40's before and i have no drone from the mufflers at all now
  7. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    Ive got a 91 burb with all stock 3" exaust tube, no cat, and a 3:flowmaster 40. (yes it goes all the way out the side behind the back tire, like factory) And mine is to loud for me. On the highway I like it alot but i hate it in the city. its just do damn loud. Im going to try iether stickin a glass pack in before it (like a resonator) or just ditch the flowmaster and get a regular old 3" turbo muffler. In conclusion If its too loud for you now its still going to be too loud with or without the full length tail pipe, and the flowmaster.
  8. NoReGrEtS
    NoReGrEtS 1/2 ton status
    Nov 7, 2005
    848
    Moreno Valley,SO CAL
    just turn the stereo up:D ooo and if its too loud your too old :D
  9. az ranger
    May 9, 2004
    139
    Safford AZ
    I had this same set up exiting out the side before and it was too loud for me then. So I would like to find a quiet muffler I would rather it be too quiet then too loud.
    anybody ever try using the glass pack as a resonator that sounds interesting.
    what other mufflers are going to be quiet
  10. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    For a mellower tone in a quality muffler I like the Magnaflow. check 'em out.
  11. az ranger
    May 9, 2004
    139
    Safford AZ
