HELP! Colby's diesel fuel question?
Discussion in 'The Garage' started by supersize75k5, Dec 28, 2006.
  1. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    colby called me from the road, he is on his way home and thinks he has a bad a tank of diesel and was wondering the signs of a bad tank??
    and if he should just use the tank up or a add more fuel to it.
    the motor is new and has about 10k on it.
    motor is running ruff in real cold weather and has alot of unburned exuast and only acting weird under load.
  2. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    FWP had this happen to him what is the temp the motor is running at? Soundls like it might be running too cold? If this is the case have him put something in front of the radiator.
  3. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    yes it is running cold, thanks!
  4. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    if it is cold outside the fuel will gel up in the filter on the pass side firewall
  5. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    X2
    Isn't there an additive you could get at a truck stop to help with this? I don't know personally because I live in South Carolina. Doesn't get below 30 here much.
  6. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    two things, he did the carbboard trick prier to calling me and thought it helped cause the problem, ie lack of air
    he also added a additive
    and last time i talked to him all was well
    so,,:confused:
    :D
  7. mxfireman
    Dec 7, 2002
    2,480
    LHC, AZ
    extreme cold and diesels don't do well together.
  8. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Add more additive & start topping off the tank as often as possible to dilute the bad fuel. You will likely need to change the fuel filter once or twice too. I got a bad tank in California awhile back. It clogged a fuel filter pretty quick.
    Harley
