HELP!!!!!!!!! Computer gurus!!!
Discussion in 'The Lounge' started by hi pinion, Jan 2, 2005.
  1. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    Ok, i bought a brand new computer 5 months ago, when i first got it, it was screaming fast, now its so slooooowww,,,,its a HP pavillion 520, 512mb, 160gb, cd rom ,. bla bla,
    Its running slow, help. That is all. Also, i have comcast , wich was superfat at first, but now is really slow even with the comcast, nothing like in the beggining, it slowly got slower day by day, later bros , jacob
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    have you defragmented the hard drive? run adaware also
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    oh also what all is running in your system tray? over by the clock? to many things will eat up all the memory and make it run slow
  4. hi pinion
    Sep 25, 2003
    5,354
    ?? i did system restore!!!! :) it worked, but i have to re-do EVERYTHING, like start all over, works killer now!!! even ck5 diddnt recognise my pc. I have some more memory, to make it over a full gig on the HD!!!! Later, Jacob
  5. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    :rotfl: Glad I could help. Oh wait, I didn't get a chance to...
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The symptoms you described are those of classic spyware problems. Go to www.lavasoft.de and download AdAware SE. Run it every few days and it will clean that crap off of your system. :cool1:
    It also helps to NOT run Internet Explorer. Using an alternate browser, such as Firefox, will prevent a lot of stuff from attaching itself to your system.
  7. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Yup Harry's right! Get some anti spyware programs AdAware or spybot. Keep your virus protection updated regularly, Get a good firewall. If you dont your puter will be runnng slow again in no time.
    If you havent already done so download the service pac 2 upgrade for windowsXP from Microsoft.
    Running a diferent browser is good. But IMO it will only be a matter of time till spyware and hackers target them also.
    I have IE and have no problems what so ever.
    System restore should only be used as a last resort. if you keep the junk out of your system you should never have to use it.
    A registry cleaner is also good to have.
  8. fordeater
    fordeater 1/2 ton status Premium Member
    Mar 21, 2004
    1,402
    Missoula, Montana
    Run adaware, and spybot both are free from download.com. If that doesn't fix the problem, start your computer in safe mode by pushing f8 when you are booting up your computer. Once you are started in safe mode, run adaware and spybot in safemode. This should really get rid of any crap running on your computer that you can't get rid of running regularly in windows.
    Doug
  9. hi pinion
    Sep 25, 2003
    5,354
    Thanks all, ill give that try,jacob:)
  10. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Don't do stupid things with your computer
  11. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    O.K. the basic windows utilities only have reset cookies,and reset history and reset cache in it. What you need is system suite. run the registery defrag, registery fixer. delete cache, protect often used cookies (delete all others), delete web histery, run hard disk defragthat shoul spped up your system imensly. Also do you have enough ram memery not enough can slow your system down.:) Good luck. It has taken me a few years to get my computer to scream, be patient, save often, and use restore points!:)
  12. hi pinion
    Sep 25, 2003
    5,354
    Ok, i ran the software, but it says "shut -down in 60 sec, then counts down, then shuts down my computer,after like 60 sec. IS THIS NORMAL? It dosent seem normal:confused:
  13. hi pinion
    Sep 25, 2003
    5,354
    also, system restore worked good for a little, now itas slow again:confused:
  14. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Save your data, do a clean install
    It's a pain, but it'll make it into the thrill killer comp again
  15. hi pinion
    Sep 25, 2003
    5,354
    I dont get it. I am completly lost:)
  16. hi pinion
    Sep 25, 2003
    5,354
    HEEEEEEEEELp
  17. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Make a complet backup of your lists, info, document, pics, files, movies, etc. then NUKE the harddrive and reinstall JUST whta you need, XP and your core programs. Then copy your files back.
    All the hidden stuff, all the factory installed crap, all the hidden creepy junk, will be gone
  18. hi pinion
    Sep 25, 2003
    5,354
    That sounds complicated:confused:
  19. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    Jacob, you have a virus (or trojan/worm) that came out a while ago. I got the same thing. Microsoft has a patch for it, but you may have to download it onto another computer, and then load it onto yours. Do a search on Microsoft for it. It is a real pita due to the fact the computer only stays running for about a minute or two. Good luck.
  20. hi pinion
    Sep 25, 2003
    5,354
    Good luck, im gonna need good luck:D Ill probly just stay infected, and live with my diseased PC, :) because its beyond my capability:grin:
