HELP! Cooked valve cover gaskets
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BowtieBlazer, Jan 19, 2002.
  1. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    I just pulled the valve covers for the first time since owning the truck...It was leaking oil from them pretty badly...the covers came off easily but usually somegasket stays attached to them of partially attached or it is still easily removed from the heads....
    This truck different story...they seem to be cooked on there and I am having great difficulty getting the surface clean again. I actually thought for a moment there was no gasket becuase the gasket has hardened that much to the heads. Any tips or tricks? I am scared my paint scraper will cause the sealing surface damage
    Granny LOW and let her GO!!
    1985 GMC C-10 Shortbed
    1984 Chevy K-5 Blazer
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    CAREFULLY spray some BrakeKleen on the sucker and let it sit for a little bit, then attack it with a gasket scraper. Make sure you cover your heads and oil drain holes with a rag because if the BrakeKleen gets into your oil it will break it down in a hurry!!!!
    <font color=red>DIGGING AND DIGGING AND DIGGING</font color=red>
  3. BowtieBlazer
    Jul 15, 2001
    2,462
    BrakeKleen is that a special brake cleaner or will any old brake cleaner work? I plan on doing an oil change this afternoon anyway
  4. Can Can
    15,552
    136
    That's just the brand I use. For all I know, you guys south of the border might have never heard of it........
    Just try your best to keep the brake cleaner from dripping into the oil passages. Even if you plan on changing your oil, there might be some residue that will contaminate your new oil. It odesn't take too much of the stuff to break down oil.......
  5. BowtieBlazer
    Jul 15, 2001
    2,462
    thanks for the help i'll try it out
  6. Can Can
    15,552
    136
    If that doesn't work you can always try some WD40, too. Chances are that you'll have to use some elbow grease.......It sounds like that sucker is gonna be tough to remove.
    Good luck, brother!!!![​IMG]
  7. BowtieBlazer
    Jul 15, 2001
    2,462
    elbow grease is the method I am having to use...so far lots of it... I think I have been working at removing all this stuff for a few hours now...such a simple project making trouble on what was my relaxing weekend
  8. Can Can
    15,552
    136
    One hint.......if you have AC it's alot easier to get the right cover back on properly if you undo the compressor bracket.......
    Sorry to hear the job has been so ugly.
  9. BowtieBlazer
    Jul 15, 2001
    2,462
    I got it all clean and fixed...used a nice thin wood scraper from a budd's house cleaned it and got it all going again
