HELP: D60 Kingpin Rebuild - Where do the parts go?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ECNiz, Mar 17, 2003.
  1. ECNiz
    ECNiz Registered Member
    Sep 9, 2000
    54
    Santa Cruz, CA
    Hello Everyone,
    I'm doing a rebuild on a dana 60, and I am having trouble remember where the 2 rubber rings go that come in the kingpin rebuild kit that I bought from randy's ring and pinion. they are black, and both have the same inner diameter, but one is a little thicker than the other, I believe one goes over the top, kingpin bolt, but I don't know which one, and I don't know where the other one goes, can someone offer advice?
    Thank You,
    Erik
  2. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    Check here. It may have a diagram of what you need to know. Are you working on just the top, or did you rebuild the bottom as well?
  3. ECNiz
    Sep 9, 2000
    54
    Santa Cruz, CA
    part # 32 on that diagram is one of the rubber rings, I'm not sure which one tho, and I don't know where the other one goes? I'm rebuilding both the top and the bottom.
    -Erik
  4. K5thatShmobs
    K5thatShmobs 1/2 ton status
    Sep 27, 2001
    353
    San Luis Obispo, CA
    They are probably the king pin seals. They go around the base of the king pins themselves. They are #28 in the diagram below:
  5. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    I'd say one is #24 and the other #28.
  6. ECNiz
    Sep 9, 2000
    54
    Santa Cruz, CA
    one is 28, but the other is not 28, 28 is one of those seals with the metal outside, and rubber ring on the inside.
    The 2 I am trying to figure out are all rubber.
    -Erik
  7. Blazer79
    1,816
    The one on the lower right corner is #28 it goes around the bottom of the kingpin, the one next to it is #24, it goes under the bearing.
  8. ECNiz
    Sep 9, 2000
    54
    Santa Cruz, CA
    In the kit I got, I got all those parts, plus another that looks like the one in the lower right, but one of them is a little thicker than the other.
  9. Flexy K20
    Flexy K20 1/2 ton status
    Oct 22, 2002
    398
    Bay Area, CA
    So lemme get this stright you got the bearing seals, and 4 all rubber seals? Two of them are the same as in the bottom right of that picture and the are two other odd ones? Later
    -fLeXy K20
  10. ECNiz
    Sep 9, 2000
    54
    Santa Cruz, CA
    I got one of each of everything in the picture, plus another rubber piece that looks like the one in the bottom right, but is a different thickness
    -Erik
  11. K5DRAGER
    K5DRAGER 1/2 ton status
    Jul 27, 2001
    1,164
    Momence, IL
    I used the same kit from Randy's. And I got the same two different seals, I was told that they where the same thing. That some years used the thick and some the thin. I used the thick and have had no problems. Not sure if this helps or not. If anything maybe a quick call to Randy's?
  12. ECNiz
    Sep 9, 2000
    54
    Santa Cruz, CA
    I'll take that answer!
    Ok, back to assembling /forums/images/graemlins/grin.gif
    Thanks guys
  13. Flexy K20
    Oct 22, 2002
    398
    Bay Area, CA
    So are you only rebuilding one side? If so, why you have it apart you really should just spend the extra $45?
    and do both sides. But that's just me. Later
    -fLeXy K20
  14. ECNiz
    Sep 9, 2000
    54
    Santa Cruz, CA
    No, I'm rebuilding both sides along with the whole axle. The thing was in bad shape when I got it, so I tore it down, sandblasted everything, and bought new parts. Problem is, I tore it down a few months ago, and since then forgot where those parts went.
    -Erik
