HElP D60 kingpin studs
Discussion in 'The Garage' started by BIGRED74K20, Feb 2, 2006.
  1. BIGRED74K20
    BIGRED74K20 Registered Member
    May 23, 2005
    82
    23
    Northwest
    i just recently bought a 2.5'' king pin spacer and one of those superlift offset draglinks for $50. but he didnt have the studs/bolts for the spacer. i thought about using grade 8 bolts but the steering arm holes are counter sunk. does anyone know where to find long enough studs? :confused:
  2. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    If you go to an industrial hardware supply (not retail like Home Depot or Ace), they should have them. Also, ditch the offset drag link becaue they suck. Get a dropped pitman arm instead to go with your raised steering block.
  3. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    Well I wouldnt recommend the block and I dont know why they are still on the market because the are unsafe. You can see that the 3 grade 8 pieces of all thread ( cant find studs that long ) that sheared right off of the knuckle which caused me to have NO steering and this happened luckily in my drive way and not going 70 down the freeway. Get a dropped pitman arm or go crossover...it could save your life as well as someone elses.http://coloradok5.com/forums/attachment.php?attachmentid=15162&stc=1&d=1138981046
  4. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    do it right and go crossover. You will thank yourself the first time you drive it.
  5. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    crossover on a 60 is so cheap and easy theres no reason not to.
  6. BIGRED74K20
    May 23, 2005
    82
    23
    Northwest
    yah looks like im gonna pass on the block. i was just gonna use that setup for time being until i purchase ORD high steer kit. how do you think just the offset draglink will work with 8" of lift?
  7. sweetk30
    Nov 1, 2004
    25,529
    527
    horseheads , ny 14845
    get the base kit for under 400 and add high steer later.
  8. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    I finished crossover this week on my 60. It isn't cheap, but man it handles like no chevy truck I've ever driven! Tight turns, smooth steering, and no bump steer...
