Help D60 spindle nut lock washer, old style
Discussion in 'The Garage' started by mrk5, Feb 5, 2007.
  1. mrk5
    Apr 20, 2004
    12,327
    1,031
    Northern Colorado
    I'm trying to figure out if I'm using the lock washer properly. I have the pre-81 style that uses the bent tabs. I installed it with the lock washer between the nuts. I torqued the outer nut and then bent a tab down into one of the slots on the outer nut.
    Is that right. Doesn't seem very efficient, but maybe it's efficient enough. :dunno:
    I'm tempted to by a set with the new style pin type lock washer/nut combo.
  2. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    aslong as that lock washer is in the groove on the spindle to keep it from rotating
  3. ou8mud2
    ou8mud2 Banned
    Nov 2, 2004
    18
    Stow, Oh
    bend the tab onto the inner lock nut, so if the outer nut ever loosens the inner one will(should) stay put.
  4. mrk5
    Apr 20, 2004
    12,327
    1,031
    Northern Colorado
    That's what I was wondering. I thought that made more sense.
