Help! Darn swaybar bushings!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Dznutz70, Dec 27, 2001.
  1. Dznutz70
    Dznutz70 Registered Member
    May 18, 2001
    21
    San Ramon, Ca
    I am trying to install a set of ORD Swaybar disconnects I got for Christmas. All was well till I took out the passenger side bolt, the metal thing that goes inside the bushing came out with the bolt. I got the metal thing off but how do I get it back in the hole?
  2. RAY
    RAY 1/2 ton status Premium Member
    Jul 4, 2000
    281
    Austin, Texas
    i'm having the same problem. I am going to take the swaybar and bushing to a machine shop and have them press them in. I have tried pressing them in with no success. You might try greeasing them real good.
    Good Luck, Ray
  3. Dznutz70
    May 18, 2001
    21
    San Ramon, Ca
    I tried lots of grease and pressing it in. I am going to put a longer bolt on it and try and screw it threw.
  4. Dznutz70
    May 18, 2001
    21
    San Ramon, Ca
    Well I used the longer bolt provied with the kit and got it halfway through and then used the old bolt to get it most of the way but it is sticking out about a 1/4 inch. Anyone now how to get it the rest of the way through?
  5. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    Do you have a piece of wood you can lay over it and hit it with a hammer.
    What kind of bushings are you using? Mine went in no sweat.
    <font color=blue>Answers: $1, Short: $5, Correct: $25, dumb looks are still free.</font color=blue>
    <a target="_blank" href=http://www.bluefox.tv/~lara>My Wonderful Site</a>
  6. Dznutz70
    May 18, 2001
    21
    San Ramon, Ca
    The bushings are the stock ones. I think that it is in enough to fit into the disconnects and that will be fine till I can order another set of bushings. Any recomendations on which brand to use?
  7. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    Get some poly bushings. I got the energy suspension sway bar bushing kit. I had to machine the sleeves some so the ORD disconnect kit would work. The sleeves are a little thicker, but smaller also. The factory stuff fits thru it, but the ORD didn't. But after that everything went in just fine, plus the two front bushings are greaseable.
