"Help Design" a new D60 Cross Over Steering Arm
Discussion in 'The Garage' started by 45acp, Mar 24, 2003.
  1. 45acp
    45acp 1/2 ton status
    Jan 3, 2001
    695
    Tucson, Arizona
    \"Help Design\" a new D60 Cross Over Steering Arm
    I am interested in designing a new “Crossover Steering Arm” for my Dana 60 and if it works we would then put into production for everyone. My thoughts for needed improvements are as follows but this is where I need your help. Correct me where I’m wrong and give me your ideas of what you think is needed. This will not be an economy design, I am interested in the best, not the cheapest since this is for my own truck.
    1. The arm needs to be raised by at least 1” and this should be built into the arm, not a spacer.
    2. The arm will be made for a super heavy stainless “Heim Joint” that will be put into double shear.
    3. The joint will be sealed with a boot and packed in “Marine Grease” for protection.
    4. The counter bore for the spring will be machined and will not require a cap.
    5. The four bolt holes will be counter bored and sunk for the proper nuts and standard length studs.
    6. The material will be stainless steel to eliminate corrosion and the need for paint.
    ADDED SUGGESTIONS:
    7. Threaded perload for the kingpin to adjust for DW.
    8. Double arms for rear mounted tie rod.
  2. OL14BLAZ
    OL14BLAZ 1/2 ton status
    Aug 14, 2002
    1,815
    TEXAS, USA
    Re: \"Help Design\" a new D60 Cross Over Steering Arm
    Sounds like a great arm you are wanting too make. I would be very interested in them for my K5. I have been looking into these:
    I would like to see how yours come out first. Also will you offer a complete Hysteer kit with both arms, draglink, tierod and ends?
    Keep us posted /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
    Eric /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  3. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    1.perfect
    2.mmmm beefy
    3.great idea
    4. a must in my book
    5.another yes
    6.that might make the Bling Bling a little to Bling Bling
    7. price will be a major factor. i'm also guessing the drag link and the tie rod will all be super heavy stainless “Heim Joint"
  4. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I for one wouldn't want to use a Heim joint. TRE is fine.
    Why stainless steel? I think that would add cost without adding much benefit.
    So, how's the Eldo ebrake bracket coming along?
    -- Mike
  5. 45acp
    Jan 3, 2001
    695
    Tucson, Arizona
    Mike, The stainless does not cost huge amounts more and does eliminate the corrosion issue. From what I have read about using heim joints the major complaint is not being able to seal them from dirt and water. They do offer more angle of movement.
    On the ebrake issue: Every idea I want to use requires that I put the body back on my frame for measurement and I am just not ready to do that yet. What I want to do is design it for the use of two VW brake levers to the center between the seats for cutter brakes and one cable to each rear brake. The other problem is Aerospace work has picked up for the first time in two years and we are having problems keeping up with that and the Offroad stuff.
  6. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    How good is Stainless for this application from a mettalurgical standpoint? I recall someone saying that stainless is too soft for a steering arm...I mentioned using T-1 and was shot down also.
    I do not like mild steel for steering arms though, there has to be a better material.
    I love the rest!
    Rene
  7. 45acp
    Jan 3, 2001
    695
    Tucson, Arizona
    Rene, The material that I would use is 17-4 PH and would be heat treated to about 48 "C" and is way strong enough. Probably my usual "over kill" but thats the way I like it. Did you notice my comment obout increase in Aerospace? Thats good for both of us.
  8. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    10-4 Bill...not to doubt you, just playing Devil's advocate as usual /forums/images/graemlins/grin.gif
    Yes I noticed the other part about being busy. I worked 55 hours last week and will prolly work the same or more for many weeks to come. /forums/images/graemlins/thumb.gif
    We're starting work on tooling for the new Strike Fighter some time in the summer, plus more for Airbus, and Raytheon. I'll be lucky to have any K5 time.../forums/images/graemlins/eek.gif
    Rene
  9. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Everything sounds good, but have you ever thought about putting making the arm for both sides, that allow the tierod to be placed behind the axle? Basically, you just need to have the passenger side arm as a double arm, but keep the draglink side tapered, etc, like you suggested.
    I think this will be the hot ticket right now...much better than hi-steer, if you can make it work...
    Just a suggestion.
  10. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    any thoughts on a threaded kingpin spring preload adjustment for DW removal?
    I guess shims are safer way to fly in that regard?
    more testing needs to be done to determine the required pressure.
    can't wait to see the results
  11. 45acp
    Jan 3, 2001
    695
    Tucson, Arizona
    MJ, Thats a super idea and it would not be that difficult to do. By the way, how did you resolve the issue that you PM'd me on regarding overnite stays in bad areas of LA?
    Boss, I would consider the double arm for a tie rod in back but I am not sure how much of a bad effect would result in the steering for the trucks used on the road. I also keep hearing stories about breaking the top of their knuckles from doing this kind of thing. Any input on this would help in making a decision on adding this feature.
  12. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I am still relying on sheer luck and a ball peen hammer /forums/images/graemlins/smirk.gif
    when I can I drive out to Ontario CA where there is a truckstop at the I-15 I-10 intersection
  13. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Re: \"Help Design\" a new D60 Cross Over Steering Arm *DELETED*
    Post deleted by BadDog
  14. thatK30guy
    Jan 12, 2001
    32,076
    55
    Bill, I have frequented the POR site and they often show some D60 hi-steer with crossover arms in one. But most of them the guys make over there don't look very good. I would prefer a part that looks good, is beefy, and will perform to the expectations without worries of failure.
    I will find a link I have of some hi-steer arm pics I have and let you view them. Be aware these pics are to fit a D44 but will give you a general idea of how to make a hi-steer D60 arm to make it "prettier."
    These arms I have seen posted on POR have the tie rod mounted on the rearward part of the front axle, up above the springs. The drag link hooks to the passenger side like any other crossover arm. Just keeps the tie rod up higher and out of the way of harm.
    Let me find some links and post them up for you to see. /forums/images/graemlins/thumb.gif
  15. thatK30guy
    Jan 12, 2001
    32,076
    55
    I forgot one more thing to take into consideration: Design 2 different arms....one to clear conventional tire/rim combo's and one to clear Hummer rims. /forums/images/graemlins/wink.gif
  16. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    How do you plan to build these? CNC? Plasma Cutter Table? I can draw anything you need in AutoCAD for your CNC Machines. /forums/images/graemlins/thumb.gif
  17. 45acp
    Jan 3, 2001
    695
    Tucson, Arizona
    Russ, I'm always interested in new ideas but I don't follow this one. Are you referring to crossover steering arm or something else?
  18. 45acp
    Jan 3, 2001
    695
    Tucson, Arizona
    Wes, I assume that the Hummer wheels have much more back spacing. How much would the arm need to be offset toward the frame to clear the wheel?
  19. Emmettology 101
    May 9, 2000
    8,126
    FL
    I 2nd what Westy said and make a angled in hummer wheel version... Also, a TRE version....
    Another thing is to have the heim/tre mounting surface angled like Avalanches.
  20. 45acp
    Jan 3, 2001
    695
    Tucson, Arizona
    Neil, We have a solid modeling program call "IDEAS" by Unigrafics and the machines would be CNC machining centers made by Matsuura. However, I just read your profile and realized that your profession is design. We are really busy right now and it will be very hard to free one of my guys to work on this project. If you want to work with me on this and creat a design/cadfile (3D/IGES or 2D/DXF) I would be glad to make the first one free of charge for your truck. We should probably take this to a PM instead of this thread.
