Help diagnose 700R4 problem
Discussion in 'The Garage' started by mouse, Nov 14, 2006.
  1. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    A friend of mine is having problems with a freshly rebuilt 700R4. Around town it drives fine, but once it gets a few highway miles it loses overdrive and seems to be overheating. It puked some ATF out the dipstick tube last time.
    When we checked to B&M cooler, it felt hot (really hot) on one side, but cool on the other side. The lines were the same way, in was hot, out was cool.
    He was losing reverse after the highway drive as well.
    Could it be a partially blocked cooler? The cooler is a new plate-type unit.
  2. scooter122983
    scooter122983 1/2 ton status
    Oct 4, 2006
    297
    Fond du Lac, WI
    do a full flush of the system by pulling the outlet line on the cooler and running the engine while puring clean fluid in the dipstick tube. This should clean out whatever is clogging the cooler.
  3. Drewzz
    Drewzz Registered Member
    Nov 14, 2006
    7
    Regina, Sk, Canada
    Flush it and make sure the kickdown is adjusted properly or your pressueres will be off screwing the trans.
  4. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    I know a lot of people use Vaseline to retain the check balls inside the valve body. Its usually fine because it dissovles pretty easially, and is removed with the flush that should be done after the first few miles.
    Id say flush it, put a new filter in, and see what happens.
