Help diagnose my problem
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ryan2286, Mar 15, 2003.
  1. Ryan2286
    Ryan2286 Registered Member
    Nov 7, 2002
    32
    South Suburbs of Chicago
    On initial acceleration a rythimic clunking and clanking is heard. After that while maintaining a speed of 35, or any speed for that matter, and more throttle is applied a low hum and vibration can be herad and felt. But once a steady speed is achieved the vibration and hum goes away. My trans fluid is still red, my t-case has enough oil and my diff was just oil changed 4 months ago. If the transmission is put in park or neutral the motor runs like normal under all throttle positions. What are some things I can do to determine the problem. Thanks for any help
    -Ryan
  2. jc71355
    jc71355 1/2 ton status
    Jan 13, 2002
    830
    Port Neches, Texas
    Check your U-Joints
  3. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    Does it sound like metal on metal? Almost like a tinny noise? /forums/images/graemlins/burb.gif
  4. Ryan2286
    Nov 7, 2002
    32
    I just replaced my driveshaft to diff u-joint two weeks ago, perhaps its the top one thats causing the problems now
  5. Ryan2286
    Nov 7, 2002
    32
    yes it does, sound like a tinny noise, initially, then it turns into the deep vibration. but in like the first gear under acceleration yes it sounds like metal clanking on metal
  6. jc71355
    Jan 13, 2002
    830
    Port Neches, Texas
    I had similar conditions w/ a very fast vibration and It ended up being the upper U-Joint. Found that out when it blew going 70 on the Highway /forums/images/graemlins/eek.gif
  7. sdavid
    sdavid 1/2 ton status
    Aug 5, 2002
    244
    Livingston, TX
    Sounds like a U-joint. Also check to make sure the end you just replaced is still tight and no loose bolts that hold the U-Joint to the diff.
