help: diff fluid change
Discussion in 'The Garage' started by blazerpro79, Mar 26, 2005.
  1. blazerpro79
    blazerpro79 1/2 ton status
    Jan 4, 2005
    528
    Simi Valley, CA
    hey guys im going to paint my diff cover, and need help changing my differential fluid. i have a few questions...
    how do i know when it is full? and what grade you guys suggest for new gear oil? thanks a lot.
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    your going to paint your diff cover??
    well if you just want to change the fluid for the hell of it just fill it up till it comes out of the fill hole.
    I use 80/90
  3. blazerpro79
    Jan 4, 2005
    528
    Simi Valley, CA
    ya i want to take it off to paint it... my truck is more of a street cruiser. ill post pics tomorrow
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Just fill the diff till it comes out the fill hole. Should be 3-4 quarts normally. If it gets hot where you are in California then I would run 85W-140 gear oil. It will take the heat better then 80W-90 will.
    Harley
  5. blazerpro79
    Jan 4, 2005
    528
    Simi Valley, CA
    do i need limited slip diff fluid or anything special? im doing the front and back.
  6. Big Red
    Big Red 1/2 ton status
    Jan 9, 2003
    250
    Bristol, CT
    if u have a L/S, then yes, u'll need to add an additive to it. Advance sells it for like $5. I used it all the time till my tranny blew. lol.
  7. blazerpro79
    Jan 4, 2005
    528
    Simi Valley, CA
    i know if i have limited slip if:
    i jack it up and one wheel spins with the other? or is that posi?
  8. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    The front won't have a posi unless it is aftermarket so you don't need the additive for that. If the rear has the govlock you should probably add the modifier into the diff. I was always told to use the GM additive from the dealer. I think it was like $8 or something like that.
    Harley
