Help!!!!-------Disconecting wiring from gas tank
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Derf00, Oct 29, 2000.
  1. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Have dropped gas tank on my '90 Jimmy to remove for repair. How does the wiring for the sending unit disconnect?
  2. stephan van leir
    stephan van leir 1/2 ton status
    May 4, 2000
    181
    central Colorado
    I am not sure if this will help. I check my 75, and my 83 k20 diesel for the wire mounting. Both only had a brass stud that was mounted to the sending unit. The wire terminal just pushed down on the stud. The tank to the K5 is out of the frame, but the k20s tank still had the wire conected. I had to lightly pry it up off the stud. Since you`r `90 is EFI things could be very different though. Good Luck.
  3. Derf00
    Jul 25, 2000
    1,683
    Abilene, TX
    Thanks for the reply, but mine is different than that. Three wires going into a plastic connector on the sending unit. I know I can cut them, but I would rather ask than be sorry I didn't.
  4. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    There is a disconnect by the frame and you also have to take a ground of the frame in the same general place. You should not have to cut anything just look around. - Doug
    Doug Krebs
  5. Derf00
    Jul 25, 2000
    1,683
    Abilene, TX
    Thanks Doug, the plug was covered up by mud, I just didn't look close enough.
