Help! Doing my own dual-Tcase setup...
Discussion in 'The Garage' started by dhdescender, Apr 18, 2003.
  1. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    I hae a milling machine, and lots of time and knowledge on my side, so I figured I'd fab up a dual T-Case setup for my K5.
    I'm either going to do direct adaptors (like ORD) or adaptor to factory adaptor.
    I havent aquired a NP203 as of yet.
    My question: The adaptor shaft (usually a cut down Transmission shaft..no?) I will need from the NP203 to the NP205 input (I'm using a 32spln BTW), does the gear end that plugs into the NP203 have to be made, or is it the stock gears from the transmission output, with simply the other end resplined? I read an article on BC 4x4.com that implyed that they had used a TH350 output shaft, and resplined 1 end, leaving the tranny end to plug into the NP203.
    So. Can I get away with resplining just the one end, that plugs into the NP205, so am I making a whole new shaft?
    I'm trying to buy as little as possible, but I might be forced to buy the SM465 to 32 spline NP203 input shaft. ah well.
    Eveyone needs a vertical mill. /forums/images/graemlins/thumb.gif
  2. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    The stocker's have a Sleeve inside the T Case support that connect's the T-Case to the Transmission. The sleeve also has 2 seal's on either end of it.
  3. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    I agree, but all the ones I'm finding local have more backlash than table travel /forums/images/graemlins/ignore.gif /forums/images/graemlins/1zhelp.gif I have access to 5 mills though, plus 12 lathes and 1 horizontal mill so I'm ok for now though /forums/images/graemlins/grin.gif But I do wish I had my own in the garage...
  4. dhdescender
    Aug 10, 2002
    628
    Are the TH400 type (32 spline) not lacking this extra sleeve. I was under the impression the sleve wasonly on TH350 and SM465 versions.
  5. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Check out the BC4x4 boys. Someone has done this before. /forums/images/graemlins/thumb.gif
  6. dhdescender
    Aug 10, 2002
    628
    BC4x4 is where I'm getting my info.
    He said he 'sent the shaft off to moser for resplining' however, from the picture, it looks as if the NP205 end was the only end resplined, and the TH350 end of the shaft plugged right into the NP203.
    BUT. It doesnt specify either way, I hate to assume. It costs time an money.
    Here...let me see if I can better explain:
    As I read the article (http://bc4x4.com/tech/2000/gordtcases/gordtcases.cfm) he shows this picture of the shaft work done.
    I interpret that picture as Stock TH350 output shaft (front), and modified shaft and coupler at the back, as it looks like NO resplining was done to the modified shaft on the Tranny end of the TH350 output adaptor.
    It doesnt really matter that I'm using a Turbo400 NP205, all my qestion is, will the tranny end of a TH350 output shaft, bolt into the NP203 without mofication.
    I'm well aware the other end will need resplining to 32spline.
    Thanks all! Keep talkin! We'll get it solved
  7. dhdescender
    Aug 10, 2002
    628
    Ok, on ONE hand drawing it says 'unaltered shaft section' indicating that the TH350 shaft WILL plug into the NP203.
    Now which NP203...is it only the TH350 version.
    I'm killing ya, I know /forums/images/graemlins/rotfl.gif
