HELP!!! Driveshaft.. and Brakeline Q's
Discussion in 'The Garage' started by jekquistk5, Jul 11, 2004.
  1. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,012
    842
    Pinckney, MI
    HELP!!! Driveshaft.. and Brakeline Q\'s
    Ok guys, so i have the front tc 6" springs on, but to get the ubolts on i had to disconect the front shaft. It seems to be about 2 inches short. Everyone ive known hasn't had a problem with this. Heres what it looks like
    My other problem is the brake line obviously there too short. I have the brake line relocation bracket, but its no help to me i do not see how to get it on heres what i have it down too.
    I tried searching for post but i couldn't find anything well atleast not on the first 2-3 pages
    thanks
    Jess
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    Re: HELP!!! Driveshaft.. and Brakeline Q\'s
    time for new drivwshafts
    the brakeline gets moved to under the framerail
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Don't lower your brake lines. Get yourself some extended hoses via the part numbers in the advanced previews forum.
    As to the driveshaft, have it lengthened locally.
  4. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    Get the Napa brake lines. I just did them two days ago. They are perfect for a lifted truck. PM me if you need the part number.
    -Chris
  5. jekquistk5
    Jan 18, 2004
    11,012
    842
    Pinckney, MI
    Where can i take the shaft, i need this thing to be together by tuesday. You say locally, like what kinda shop could do that. Standard service center???
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    A driveline shop. We've got a number of them here.
    If you can't find a shop open the phone book and look up transmissions. A local transmission shop should be able to tell you who can lengthen your shaft for you.
    You don't need a front shaft to drive it anyway. remove it, measure from the flat surface of the flange to the center of your pinion yoke, and take your old shaft into the driveline shop along with that measurement. They will re-tube your shaft and balance it along with replacing your u-joints and you can just bolt it back in, ready to rock and roll.
  7. jekquistk5
    Jan 18, 2004
    11,012
    842
    Pinckney, MI
    Ok im headed to a shop tomorrow that should tell me where i can go. Im going to pull the drive shaft, and take the truck to place that can torch off the manifold stud that i busted off(Friggin Michigan RUST). Then I'm all set but it should be drivable tomorrow after i get the brake lines
    jess
