Help! ECM-B keeps popping
Discussion in 'The Garage' started by 91GMCSuburban, Aug 6, 2005.
  1. 91GMCSuburban
    91GMCSuburban 1/2 ton status
    Dec 9, 2002
    318
    San Antonio, TX
    what the hell!
    I have replaced the fuel pump relay, had all wires checked for shorting, replaced a loose tilt steering column. I hit a bump on the street and pop!
    What could I be missing? Could it be the fuel pump itself? Could it be the ECM? I'm grasping here, help
  2. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    could be the pump. I had a pump lockup and it kept blowing it.
  3. 91GMCSuburban
    Dec 9, 2002
    318
    San Antonio, TX
    Yeah, but it could do it cold or hot. Its when I hit a major bump.
  4. wildbilzrydn
    wildbilzrydn 1/2 ton status
    Jun 27, 2005
    118
    Joliet, IL
    Sounds like the power to the fuel pump is grounding out when you hit the bump. Check for wires rubbing sharp edges and such.
  5. 91GMCSuburban
    Dec 9, 2002
    318
    San Antonio, TX
    Although I had someone check this out, I will check again.
    If any other ideas, let me know.
