Help electrical driving me nuts!!!!!
Discussion in 'The Garage' started by Moose, May 15, 2003.
  1. Moose
    Moose 1/2 ton status
    1,062
    Glendale, Arizona
    Ok guys heres the deal. A week ago I put the burb in reverse and got on it and the truck died. After figuring out there was no fuel gettiing to the tbi I replace the filter and found that the "ECMB 10 amp fuse" had blown. Replaced it and the truck started right up. So last nignt I went to back up in the drive way and gave it a little gas to get over the curb and it did it again. Did the samething again except this time it blows the fuse the minute I turn on the ign. Any body had this problem? Is it a relay. Or is it my ECM? HELP its starting to piss me off. /forums/images/graemlins/usaflag.gif /forums/images/graemlins/burb.gif
  2. mosesburb
    mosesburb For Rent Premium Member GMOTM Winner
    Apr 20, 2003
    2,172
    128
    Phoenix AZ
    Hey Moose--Call me, I think I've found it /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif.
  3. Erich_in_AZ
    Erich_in_AZ 1/2 ton status
    Mar 23, 2002
    237
    Tucson (it\'s a Dry heat), AZ
    Might be a short also. seems to have happened when you were giving it gas, so it might be due to the engine rotating in the mounts and shorting a wire, or the same thing happening with the body. I would check the accesory (not supply) side of the fuse with an ohmmeter and if it reads a ground. If it does, then you probably have a short in the wiring somewhere. Wiggle the harness in different places and see if stops reading a ground. You can also try unplugging the ECM, or the pump relay, etc and tossing a fuse in there to see if it blows. If you don't have a meter, a less scientific way is to get a box of fuses and start wiggling the harness and see if it still blows them. I don't suggest that though, as it might spike things.
    EDIT: I also found this on a yahoo search for ECMB fuse
    http://forums.vmag.com/suvcrv0999/messages/6384.html
  4. Moose
    1,062
    Glendale, Arizona
    Thanks guys /forums/images/graemlins/thumb.gif I am going to go home after work and try it out I will let you know what I find. Nick thanks for looking at a schematic for me and explaining. /forums/images/graemlins/usaflag.gif /forums/images/graemlins/burb.gif
