HELP! (Electrical)
Discussion in 'The Garage' started by MontanaLifted, Sep 6, 2002.
  1. MontanaLifted
    MontanaLifted 1/2 ton status
    Aug 27, 2002
    171
    Help! I'm chasing a ghost!
    Tail lights are the problem.
    I've got power on both sides of all my fuses that are supposed to have power, when the headlight switch is turned on.
    I've got Headlights, Marker lights, and Roof Marker lights but no Rear Tail lights and no Brake lights.
    But I have power at the Bulb Socket.
    I also 'redneck wired' a Tail light bulb and wired it straight to my battery and it works fine.
    So I've got power everywhere and the bulb works. But I have no rear lights.
    Help please I'll be hanging around hoping someone sees this soon.
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Remove the drivers side tail light lense and check that the ground wire for the rear harness is cleanly connected. It goes under one of the screws that holds the light in on that side. Also check to be sure that the wire is really attached to the ground connector. Sometimes the wire rots off inside the insulation due to road salt.
  3. MontanaLifted
    Aug 27, 2002
    171
    But if that was the case wouldn't there be NO power at the socket?
    I've got power at the socket. The bulb doesn't want to lite up though.
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    check that the socket itself isn't bad, even though your getting power doesn't mean that your getting a good connection to the bulb itself. Had to replace both my sockets cause they were wore out.
  5. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    exactly, there has to be a complete circuit to make power, requires a ground also. i think it is green wire.
  6. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    Brown- tailights/license
    Yellow-left Blinker
    Dark Green-right Blinker
    Black-ground
    Light Green-backup
  7. MontanaLifted
    Aug 27, 2002
    171
    I think that you're on the money. When I use the voltmeter I'm creating a ground with the meter leads and thats probably why I'm reading voltage. It makes sense and there is no other explanation.
    Here goes nothing...
  8. MontanaLifted
    Aug 27, 2002
    171
    Thanks guys! It was the ground wire.
