Help...Emissions in CO on a CA K5
Discussion in 'The Garage' started by goblazeinco, May 20, 2002.
  1. goblazeinco
    goblazeinco Registered Member
    Nov 9, 2001
    33
    Longmont,CO
    I have an 86 k5 that is originally from California. Does anyone know if I am going to have to pass CA emissions or will I just have to have to stay within Colorado limits. Right now it is a mostly stock motor with the exception of flowmaster exhaust. The motor is giving me problems since I took it to Nederland a few weeks ago, and I am looking at my options to swap it out.
    P.S. Has anyone used this GM crate that is at Scoggin Dickey, http://www.sdpc2000.com/cart.asp?action=prod_detail&catid=128&pid=110
  2. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    thats the motor i just put in my 86. i love it...makes so much more power than my pos 305 did. you'll need the 85 and older flexplate, crank dowel (for centering the flexplate), and a new temp send unit if your going from a 305. other than that it was just plug and play.
  3. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,953
    248
    Released from Pueblo, told I belong in Southpark
    You should just have to stay within Colorado limits and if you engine had a smog pump it still has to have one. Not sure what they will say if you dont have a catalytic converter. Just tune it and hopefully you will only have to go once. I always leaned mine out some for the test.
  4. porboy
    porboy Registered Member
    May 7, 2002
    29
    Poway Ca.
    I also just put that motor in. 100 miles and no problems yet.
  5. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    has to have the cat, air pump, coffe can and all of the other factory crap for the emissions, in other words it has to pass a visual.
    John
