Help! engine I D needed Please
Discussion in 'The Garage' started by only 31s, Mar 2, 2005.
  1. only 31s
    only 31s 1/2 ton status
    Oct 5, 2004
    224
    mass
    someone jammed a pre 82 block and heads[ because the dip stick is on opp side}under the edelbrock intake{tbi] of my new 90 sub.It works for now but for me to tweak and so forth i need to id the block and heads.the person that did this blocked exhaust passages that i need for emissions testing not to mention that pesky check light always on! Are there any markings i can look for to i d the year?
  2. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    look for the cast numbers at the rear of the block. Kind of behind the dist.. Really convenient place for them!!
  3. dyeager535
    26,975
    Suffix code will tell you original application. Passenger side, front of block, where head meets the block. Behind the alternator if it's a passenger side alternator install.
