HELP! Engine ??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Teddie, Jul 11, 2000.
  1. Teddie
    Teddie Newbie
    Jul 11, 2000
    florida
    I just got my first 4x4, a shiny purple 84 Jimmy but it needs some parts..oh like a MOTOR! I've had people telling me that I will be having problems with it and that I should get a conversion kit for a 350. Someone else told me that a v6 from a chevy truck would fit. Can Someone PLEASE HELP ME!! Thanks!
  2. AGM73k5
    AGM73k5 1/2 ton status
    1,246
    Portland OREGON
    It depends on what was originally there, if it was originally a v8 then a v8 should swap in fairly easy. You'd probably need to post more info. Is it manual or auto trans, do you know what was previously there?
    ___ __ _ _ ____ __
    AGM73k5 -- ajgm1@yahoo.com
  3. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Is it an S10 Jimmy for K5 Jimmy? K5's always came with V8's. S10's came with 4 & 6 Bangers. Mostly 6 though. If its and S10, then yeah, you need a conversion to put a 305 or 350 in it. http://www.advanceadapters.com has what you need. If its a K5, then a 350 should bolt right in. And you deinately don't want to put a 6banger in a K5. But like AGM said, we need more info to really help you out.
    Boss
  4. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Don't know you, but 6 CLYDS(250 cid) is more common in a K5 from the factory than a NP205.
  5. Boss
    2,550
    Maryland
    Really??? Oh, my bad, I didn't know K5's came with 6bangers. But, I know NP205's aint common in K5's, but I definately got one hooked up to my TH350. The original Trans is a SM465, that's why.
    Boss
  6. Boss
    2,550
    Maryland
    Man, you're right. I just looked in the spec page and saw that V6's were standard in K5's from 69'-86'. The truck probably had no kind of pick up with that little engine in there. I remember my old S10 with a V6, and I put a 3" body lift and 31" tires and that thing was struggling.
    Boss
  7. Andreas
    Andreas 1/2 ton status
    188
    Sweden
    The 250cui in the K5´s was an inline 6, not a V6[​IMG]. Oh well...[​IMG]
    Andreas
    406cui of pure sh*t[​IMG]
  8. Mint90
    Mint90 Registered Member
    Jul 9, 2000
    33
    Illinois
    I had a '79 GMC 4WD pickup with the straight 250, it was a DOG, even with a 4 speed manual. It must be worse in a K5 !
    Mint '90 K5, All Stock, All Options, 49K
