help fast!! transmission cooler question 700r4
Discussion in 'The Garage' started by mxrcr589, Jul 1, 2003.
  1. mxrcr589
    mxrcr589 1/2 ton status
    Apr 17, 2003
    148
    poop
    im puting a tranny cooler in and you connect it to the old cooler lines that goes to the radiator, there is two lines, i need to know which way they flow, theres a top one and bottom one, which one flows back to the transmission
  2. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    top should be the return line. to double check just pull it off and start the truck and put it in gear for just a second and see if the line spits fluid out or not. if it doesn't then it's your return line.
    rick
