Help feed the beast
Discussion in 'The Garage' started by toy4fun, Aug 31, 2003.
  1. toy4fun
    toy4fun 1/2 ton status
    Sep 10, 2002
    220
    Helper, UT.
    Anyone one have any links to sights that deal with high performance fuel pick ups and /or
    tank with sumps, I need a fuel pickup with a 1/2 ID or an -10 (for a 31 gallon tank) thanks
    /forums/images/graemlins/thinking.gif
  2. dyeager535
    26,979
    Any TBI tank will have a sump, FWIW. You can buy all new, steel TBI tanks for approx. $130. (steel sump too, unlike stock plastic ones that suck)
    No help on the sending unit issue, but can't see any reason you couldn't take one, and modify it with larger fuel fittings/tubes.
  3. nvrenuf
    Jan 7, 2002
    13,074
    245
    Mobile, Al.
    Competition Engineering sells this sump (pic is upside down) that can be brazed(?) onto your existing tank (Summit has it for $61.95).
  4. toy4fun
    Sep 10, 2002
    220
    Helper, UT.
    I wanted to stay from the sump idea because it hangs down even more and the pumps need to be even lower but that may be the way to go. /forums/images/graemlins/thinking.gif
    I thought about a mod. on the sending unit but after pulling it out it may be a little more then I'm up to /forums/images/graemlins/confused.gif
    thanks for the help /forums/images/graemlins/thumb.gif
  5. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    fuel cell...mine from Jaz has a sump on it with a sending unit for a GM vehicle.
  6. slimlynn1
    slimlynn1 1/2 ton status
    Apr 9, 2003
    336
    Hamden, CT
    Where did you mount your fuel cell? In the bed or where the original tank was?
  7. Emmettology 101
    May 9, 2000
    8,126
    FL
    My TBI tank doens't have a sump.. The fuel is plumbed out throw the sending unit like normal carb'd engines with the exception of having the elec. pump being on the sending unit.
  8. toy4fun
    Sep 10, 2002
    220
    Helper, UT.
    How big is the fuel cell I need to stay close too 31 gallons or bigger. I'm trying to feed a 502 Ramjet that I want to use for towing/forums/images/graemlins/thinking.gif
