Help finding the Oil sending unit wire
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Quaddawg, Jan 3, 2005.
  1. Quaddawg
    Quaddawg 1/2 ton status
    Dec 15, 2004
    113
    Cincinnati
    Still working the bugs out of my 78/80 K10 (78 chev frame/bed 80 GMC cab)
    One of the last problems, can't find the wire for the oil sending unit.. gauge is a working gauge and sending unit is there, but I can't find the wire for it. Anyone know what color it would be on a stock 80 GMC C/K 10? out of the firewall?
  2. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    mine's off white
  3. Quaddawg
    Dec 15, 2004
    113
    Cincinnati
    Thanks, I will take a look tomorrow and see what I can see..
    Hey, anyone with this general year CK, I found another small problem. When they switched cabs, they didn't get the heater/ac blower motor hooked back up. There is a plug, with the heavy purple wire to the blower, and the heavy red power wire, along with several smaller wires (I am assuming these come from the blower switch inside, it got dark on me) Does anyone have a pic underhood of where this plug is supposed to go? or what goes in it? I am thinking it may just be a resistor module for the fan speeds, but I don't know.. The plug is on the passenger side, in the engine compartment, right in front of the blower motor, between it and the AC componants, I hotwired the blower, and it works fine, but something is missing :D
    I am about to get this old beater up to snuff!!!
  4. Quaddawg
    Dec 15, 2004
    113
    Cincinnati
    I still can't find the tan wire, and that is the color the wiring diagram calls for, but still looking, strange..
    I did figure out what was missing from the heater/ac setup, it was the AC/Heater High Blower cutout relay... $12.99 from NAPA...
    Bout got the bugs worked out of the old truck...... now to get these damned exhaust leaks fixed.
  5. cyclone
    cyclone 1/2 ton status
    Oct 11, 2004
    243
    Sonoma, CA
    79 K20
    From my 79K20
  6. Quaddawg
    Dec 15, 2004
    113
    Cincinnati
    Yessir, that be the puppy!! Thanks man! I do believe I will have full control of my heat tomorrow ( and maybe even air? dare I hope? LOL) ... good old NAPA overnite...
    Gonna try the Percy's alum. Exhaust gaskets tomorrow too....... one more checkoff on the list, the old beater is certainly coming together...
    As purchased..($1250.00), from guy's back yard, being used as a shelter for lawnmowers:p:
    For now:
  7. Quaddawg
    Dec 15, 2004
    113
    Cincinnati
    Hey Cyclone, you don't have a close up of the other side, showing where the oil sending unit wire (should be tan) goes through the firewall do you? :D :D
  8. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,921
    331
    Fort McMurray, Alberta
    I'll get you a picture of mine from my 80 C25 after school :)
  9. Quaddawg
    Dec 15, 2004
    113
    Cincinnati
    Thanks~
  10. Quaddawg
    Dec 15, 2004
    113
    Cincinnati
    Any luck on that pic?
  11. Russell
    Jun 23, 2000
    7,921
    331
    I'll go snap it right now :)
  12. Russell
    Jun 23, 2000
    7,921
    331
    Here you go! This is to the right of my HEI distributer :) Its the bell shaped sender with the rubber boot connector coming out of the top. The wire is tan on mine as well. If you need a new connector, I do believe I have one sitting in my shop you could have.
  13. Quaddawg
    Dec 15, 2004
    113
    Cincinnati
    I really appreciate the trouble. But, I know what that side is supposed to look like, I just can't find it.I need to see where that wire comes from, it should be coming out of a group of wires that come though the firewall, but I don't know exactly where it comes through.
    Thanks again!
  14. Russell
    Jun 23, 2000
    7,921
    331
    I'll snap a couple more shots and post them after school again :) Mine goes into wire looming behind the engine, but I gotta pull some wiring apart to finish my EFI harness, so I can pull it out of the looming and show you
