Help! Font end is making a strange noise!
Discussion in 'The Garage' started by rawhead, Oct 13, 2003.
  1. rawhead
    rawhead Registered Member
    Dec 6, 2002
    52
    So. California
    When the truck is in 4 wheel and the hubs are locked I get a strange clunking noise comming outa the front axle when accelerating moderately/heavy and when turning. It's a 10 bolt front... and it doesn't make the noise when in two wheel. anyone have any suggestions? Thanks in advance.
  2. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Most likely a worn u joint, either on the axles, or the driveline. Wouldn't make a noise when the front axle is disengaged.
    John
  3. rawhead
    Dec 6, 2002
    52
    So. California
    Well I took another look at it and it looks like the CV joint on the front driveshaft may be making contact with the crossmember below it while under medium/heavy torque. Maybe my mounts are bad?
