Help! forgot how crossmember goes back
Discussion in 'The Garage' started by 88-383, Nov 5, 2005.
  1. 88-383
    88-383 1/2 ton status
    Sep 11, 2005
    142
    Tracy. CA
    Dial ups beware
    Take a look at this PICTURE and tell me if you think the tranny crossmember is installed right. I have 4 bolts,4 steel spacers,and 4 washers. Are the spacers supposed to go on top of the frame? or is it supposed to hand down like the picture.
    Make sure your browser is set to auto-resize pictures or else....
    km
  2. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    looks right to me. the hump is where the front drive shaft goes. i assume that this pic is taken from the rear and pointing forward. if so, and its still a passenger side drop front axle then it is right. the spacers are right also.
  3. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    those spacers normally go on top of the frame, if your lifting it a bit then it might help driveshaft angles.
  4. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    :haha: :haha: And IF that picture was taken from the front, you got bigger problems than your crossmember ... your engine and trans are pointing the wrong direction!! :D
    Sorry Mike, couldn't pass it up!!
    Eric M.
  5. PsychoticDeadGuy
    Jan 8, 2005
    753
    haha, i didnt even notice that....thanks for busting me out eric....
  6. thor
    thor 1/2 ton status
    Aug 20, 2003
    512
    Wa
    Those spacers shouldn't be used to lower your crossmember. If you really want it dropped, make up some spacers out of flat stock, it will be much stronger and locate the crossmember more securely.
    The spacers are supposed to go above the frame
  7. 88-383
    Sep 11, 2005
    142
    Tracy. CA
    Thanks for the comebacks! I'll put the spacers up on top tomorrow. That was some funny stuff about the bigger problems hahaha :haha:
    Does anyone know of any online diagrams for future refrence?
    KM
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    Looks good to me. But like the other quote says, use solid spacers of some sort rather than the spacers. Even square tubing will be better than the spacers.
    BTW, I like how clean the underside of the body is. Whats the scoop on how its so clean and spotless?
