Help - Fouled Plugs Problem
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1986Blazer, Sep 10, 2001.
  1. 1986Blazer
    1986Blazer 1/2 ton status
    Jun 13, 2001
    511
    Key West, FL - Southernmost Point
    New problem. I have the timing perfect now but the plugs keep fouling - bad carbon buildup, a few plugs are wet (possibly too much gas and it is not completely burned during combustion). I have been through a few sets of plugs. The engine start great in the morning but after it is warm, it starts but blows some black smoke for a few seconds (not that much smoke but some). I figure the carb is rich. If so would this cause the fouled plugs? I am going to adjust the carb but would like some input before I do so just incase there may be more things to do.
    <a target="_blank" href=http://www.geocities.com/keywestk5/KeyWestK5.html>http://www.geocities.com/keywestk5/KeyWestK5.html</a>
    So I says to him, I said, "get your own monkey."
    1986 K5, 350 GM Crate, 700R4, NP208
  2. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    Also check float level, lose cover screws, stuck or inopretive choke. If carb has alot of miles maybe time for rebuild.
  3. BigTex
    BigTex 1/2 ton status
    Dec 27, 2000
    974
    South Texas
    What gas do you use? Mine ALWAYS foul up when I use regular unleaded. Also, if you are adding any additives to your fuel, they also cause deposits on the plugs. I used to have that problem. Running super-unleaded is the best for my truck.
    <font color=red>"Maybe you could drive better with that cell phone up your azz?!!!"</font color=red>
  4. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Is this a fresh motor, if so, a quench gap above .035" can cause carbon and hot spots in the combustion chamber at normal operating temperature. Are you pinging under load?
    What, Me Worry?
  5. TwoCrowsDesign
    TwoCrowsDesign 1/2 ton status
    Jul 13, 2001
    387
    Possible bad oxygen sensor? Worth looking at, I suppose
    John
  6. 1986Blazer
    Jun 13, 2001
    511
    OK, thanks.
    No 02 sensor, the carb has been rebuilt, I have used some additives but only in one or two tanks.
    Will a lean mixture cause this problem????
