HELP: Front Drive Shaft
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Robin, Aug 2, 2002.
  1. Robin
    Robin 1/2 ton status
    Oct 30, 2001
    184
    Georgetown, Texas
    Does the front driveshaft disassemble at the telescoping end like the rear driveshaft? I was finally able to get it to move about an inch from fully compressed. I've done all the hammering I care to do to get it off.
    Any suggestions? /forums/images/icons/mad.gif /forums/images/icons/confused.gif
  2. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Yes it does. There is a retaining sleeve that has to be threaded off before the slip joint will come completely apart.
  3. Robin
    Oct 30, 2001
    184
    Georgetown, Texas
    Yeah I figured that out, but even when I slip the sleeve off, the splined end won't move more then an inch. It seems to have a hard stop.
  4. skyblazer
    skyblazer 1/2 ton status
    Oct 1, 2000
    209
    Houston, TX
    Weird, mine pulls right out. I don't know of anything that should be holding it up..hmmmmmm. Unless you have a super secret snap ring, I'd say spline damage.
  5. Robin
    Oct 30, 2001
    184
    Georgetown, Texas
    You're right on the spline damage my friend.
