HELP!! FUEL PUMP *@#$%^&*(
Discussion in 'The Garage' started by jakeslim, Oct 27, 2002.
  1. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    OK, i have worked and changed many engine parts, some were easy and some were hard. How the heck do I get the fuel pump back on onto my 350? I made sure the rod was up and not blocking the fuel pump "arm"(you know what i mean" but it still will not allow me to line up the bolts and mount.
    Does the engine need to be bumped a couple of times to rotate cam so that mechanical push rod is further in?
    Please, anyone a little help for this 77 blazer owner!
  2. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    That would make it a little easier if the cam was in the lo position so you could get the bolts started.
    Bill
  3. hammer
    hammer 1/2 ton status
    Aug 29, 2001
    449
    Binghamton N.Y.
    try rotating the engine and see if it can go in any farther. also put a longer bolt in the front of the engine to hold the rod in place. Don't forget to put the short bolt back in when you are done or you go crazy why you don't have a fuel pumping up
  4. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    thanks, that was a guess, but you've confirmed my thoughts.
    Of course I was in the engine compartment till it got dark on me, girlfriend could'nt hold flash light straight, shop light was busted from timing belt change on honda.....the usual stuff! I will try tomorrow(east coast here so its dark).
    Thanks again
  5. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    thanks hammer. I guess you have been thru this. Two bolts, 3 hoses and a couple of hours wasted. Well at least I was able to complete my interior carpeting back half of blazer today. I insulated floor, sides and wheel wells with insulation and carpet. Looks excellent.
    thanks again for input
