HELP! gas tank skid plate removal??
Discussion in 'The Garage' started by Jonny-K5, Nov 15, 2003.
  1. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    im about to do the ORD shackle flip. whats the easiest way to take off the skid plate on the gas tank? do i have to pull the bumper or hitch off? i cant see any access to bolts in those areas.
  2. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    DON'T take the bumper off. Open your tailgate and look straight down between the body and tailgate. I think there are at least three bolts that hold the skidplate on, and the double nuts that hod the gas tank straps. Be sure and spray the double nuts with PB Blaster or WD40 before attempting to remove them, these are easily broken. On the front side, the skid plate is held on by bolts that go from the top down and you can't see them, they are on the corners, and don't remember if there is one in the middle.
  3. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    thanks for the quick response. i would have never thought to look down from the top. time to get to work!
  4. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    i had to loosen my hitch to install my skid plate. so you might have to loosen it up to remove it too.
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    There are 3 bolts in front and 3 bolts in the rear. Remove those and the skid plate is ready to drop out of the way. But yeah, the trailer hitch will most likely have to move out of the way also.
  6. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    thanks for the tips guys. my hitch was in the way, so i decided to just let it hang onto the tank while i dropped it until it cleared the hitch.
    now ive got a real problem, ordered the greasable bushings, but wrong spring eye bushing size! /forums/images/graemlins/mad.gif couldnt tell until i torched them out. damn metric [darn] , guess i didnt measure correctly.
  7. 88jimmy4x4
    88jimmy4x4 1/2 ton status
    Oct 19, 2003
    947
    3
    Houston, Texas
    What year is your K5?
  8. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    my truck is an 89. i decided to band-aid fix it by leaving in the outer shell and trimming the outside of the bushing. its a tad bit loose, but it'll work till i get replacements in.
  9. 88jimmy4x4
    Oct 19, 2003
    947
    3
    Houston, Texas
    Just curious because Mines an 88 and the stocks were 1-3/8"
