HELP!!! Gear pattern cannot be seen!!!!
Discussion in 'The Garage' started by SuperCell, Feb 12, 2006.
  1. SuperCell
    SuperCell Registered Member
    Feb 6, 2006
    5
    Lost
    This is really pissing me off!! I've installed a new gear-set in my 14-bolt, and when I brushed the supplied compound onto the gear teeth, you couldn't really even see the pattern. I then tried using white grease and still I get the same result! It looks like the grease is being wiped off the entire tooth, not just a small spot like it should???
    I need help on how to get a more clear indication of the pattern.
  2. 6.2puller
    6.2puller 1/2 ton status
    Jul 8, 2004
    569
    New England
    A add a little gear oil to the paint and it marks better.
    B move the ring gear away from the pinion if you think it is taking all the paint off.
  3. johnathan
    johnathan 1/2 ton status
    Sep 26, 2005
    376
    Ocean Springs,MS
    tooo muck compound probably.put some resistance on the gears.hold your hand over the ring gear and apply pressure as you spin them
