Help guess my RTI!
Discussion in 'The Garage' started by koldsimer, Dec 8, 2005.
  1. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    After constant tweaking and fine tuning, I think I have my suspension working pretty well. Since I dont have an RTI ramp, I was wondering what I am ramping in these pics. Any ideas? The wall was probably 18-20* and the back wheel was 52 inches off the ground. Care to take a guess?
  2. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    nice pics! No idea how high, but looks good, i'm going to have some of those later this month probably
  3. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    :bow: very nice. no idea what the rti would be tho
  4. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    go to 4lo.com they have a RTI calculater on there.
  5. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    what is your wheelbase? stock is 115 right? i figured you were a little longer, so with 117 your rti on a 20* ramp would be 1299
  6. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Very nice K. Soon we will be very similar on that.
  7. koldsimer
    Jan 10, 2005
    1,480
    texas
    Thanks for all the input guys. I think the 1299 estimate is off.... I wish I had those kinds bragging rights. I would have guessed it was about 800-900 but I have no real idea. I wonder how much further I could have gone... the truck hit the building.
  8. koldsimer
    Jan 10, 2005
    1,480
    texas
    I'm also thinking that ledge was only about 15*, maybe less.
  9. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    with the stock wheelbase of 106.5" and the tire 52" above the ground, the RTI is 1428 on a 20* ramp.
    that is some awesome flex, what do you have for suspention?
  10. tRustyK5
    Jul 23, 2000
    36,166
    1,364
    E-town baby!
    x2
    Rene
  11. koldsimer
    Jan 10, 2005
    1,480
    texas
    Thanks Man. I've got 6" BDS springs up front with a zero rate, shackle hanger moved forward, longer shackles (6.25") and furd shock towers with 14" shocks. In the back i have ord's flip (swapped sides) with 4" superlift 56'ers with the overload removed and 6" long shackles.
  12. 79k20350
    Nov 22, 2004
    7,757
    Ct
    i didnt realize the wheel base was that short:D remember i got/ had a longbed. but yeah the 14XX was definetly right if you were 52" off the ground
  13. koldsimer
    Jan 10, 2005
    1,480
    texas
    Not being able to believe the RTI calculator on 4lo, I went back to the ramp with my angle finder and tape to get some measurements. My wheel was 51" off the ground. I pulled a straight line from the bottom of my wheel on a 20* plane. Total length was just over 148". This is within one inch of what it said my amount should be. So, am I to believe that my blazer is capable of 1300+ on an RTI?! Holly sheet if it's true!
  14. txfireman110
    txfireman110 1/2 ton status
    Nov 1, 2003
    294
    San Angelo, TX
    As long as you now two of the factors, ie: wheelbase, and how high one tire can go off the ground before any other tire loses contact, you can solve for RTI on this site!
    http://www.offroaders.com/info/tech-corner/rti.htm
    The calculator is near the middle of the page. Enter a degree for a "ramp", and it will give RTI for that particular Degree of slope.
  15. koldsimer
    Jan 10, 2005
    1,480
    texas
    That uses the same formula that 4lo uses. It also told me i was ramping 1350+! Does anybody have an idea what is the max rti they remember being put up by a leaf spring blazer?
  16. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Remember you're talking about a 1300 on a 20 degree ramp. It will be less on a 30 degree ramp. On a 30 degree ramp you're doing pretty much 1000 on the nose as far as I can calculate.
