help harmonic B stuck....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mudrunner78, May 26, 2004.
  1. mudrunner78
    mudrunner78 1/2 ton status
    Sep 7, 2001
    366
    Rocksprings, TX
    ok I have a harmonic b stuck on my 454 crank, I have a puller it pulled it about 1/4 of an inch off and now it will not budge. I ahve tried heat on the hub but no luck any Idea's I need to get this thing apart to get to the machine shop tommorow
    Thank s Jesse
  2. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    Did you happen to maybe not pull it out completely parallel with the world if that makes sense? In other words, did it start to get cockeyed on the way off? Try tappin (not beatin to awful hard) on the balancer to maybe get it back into proper alignment.
    This is of course if I understand your question properly.
    Good luck to y'all in the future.
    Allan
  3. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Seat the damper back on the crank, make sure the puller has the bolts threaded in all the way and start cranking on the forcing screw. when it starts to bind up smack the end of the forcing screw with a large hammer to shock it and start cranking it down again.
    You may have to work it by seating it and pulling it several times.
