HELP...headlights don't work
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wsudu, Jul 23, 2001.
  1. wsudu
    wsudu Registered Member
    Jun 30, 2000
    Wichita, Kansas
    HELP...headlights don\'t work
    The other night I noticed when I turned the corners My headlights got brighter....So then after I stoppped the truck, I tried to turn it back on, no power. I figured out that the postivie came off and grounded. So after replacing the starter, everything worked Except the headlights. But when I turn the brights on, all 4 work. Head lights actually have like two fillaments in them right; a high and low beam? I mean the on switch works and the bright switch works, so could I have burnt out the low beams in the 2 upper lights? Anyway so I turned on the brights and just diconnected the lower 2 lights for now. Help me out guys...Thanks
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    Georgetown, TX
    Re: HELP...headlights don\'t work
    See if there's 12 volts to the low beams when they should be on. If so, then both low beam bulbs are dead. There are 2 filaments in the low beam bulbs, one for low beam and one for high beam.
