HELP HELP HELP please. How do i remove the pinion shaft from a 12 bolt
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by zach78k5, Mar 2, 2004.
  1. zach78k5
    zach78k5 1/2 ton status
    May 14, 2000
    406
    After I removed the bolt that holds it in place, I am not sure how to get the darn thing out. Can I pound it out from the other side. Once I get that thing out I will be fine but I cant figure it out. Is there an easy way?
  2. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Re: HELP!!!! How do i remove the pinion shaft from a 12 bolt
    Did you take the carrier out? If so beat the pinion where the nut was with a dead blow hammer or rubber mallet and it will come out.
  3. zach78k5
    May 14, 2000
    406
    i cant take the carrier out until i remove the pinion shaft and the axles. the carrier is in the truck. does it go all the way through the carrier? can i hit it from the other side?
  4. zach78k5
    May 14, 2000
    406
    btt
  5. dyeager535
    26,979
    You might try rotating the carrier and trying from the other side. The pinion shaft will sometimes score pretty badly, which apparently prevents them from coming out easily.
    Ideally they should come out smoothly, but I've had a few that need a couple of taps with a hammer and big brass punch. Just push it through enough to get started though, if you push it too far through, it can get wedged up against the pinion, (locking the whole assembly in place) and if the pinion shaft doesn't move easily in the first place, you can't just reach in there and move it back.
  6. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    How long was the bolt when you removed it?
  7. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    He's trying to remove the carrier cross pin isn't he?
  8. 4xcrazy
    Oct 31, 2003
    9,471
    5
    If that bolt isn't like 1.5 inches or so, threaded with a 3/4 inch smooth tip, it broke off in the carrier, it took me about 2 hrs of fiddling with small magnets and picks and whatever else i could find to stick to the remaining part, while slightly twisting and rocking the carrier back and forth to get that little pos outta there,
    it's fun,, /forums/images/graemlins/rolleyes.gif
  9. zach78k5
    May 14, 2000
    406
    I guess that is what it is called. the manual called it a pinion shaft. it is the piece of steel that is keeping me from being able to move the axles inward in order to remove the c clips from them. basically it is pinned between the ends of the two axles.
    It wont come out. should I try to get the carrier hot and see if it is easier to get it loose?
  10. Fubeca
    Dec 18, 2002
    2,100
    Denver Area
    You should not have to heat the carrier to get it out. Are you sure got the whole bolt out?
    Are you able to move the axles in and out at all -- there should be a little bit of in-out play with the cross pin in.
  11. zach78k5
    May 14, 2000
    406
    the bolt is just long enough to put some pressure on the the shaft. if I hold it up on the outside of the carrier it is the exact length to touch the shaft. should it have been longer? the end looks to be sort of round like the shape of the shaft would be.
  12. 4xcrazy
    Oct 31, 2003
    9,471
    5
    Yes, there is a piece that actually goes into the shaft into a hole, there is still a piece broken off in there, this common, as far as removing it,,,,gonna have to get a bunch of different ideas.
    So all you really have is the bolt head and treads, right?
  13. zach78k5
    May 14, 2000
    406
    I have the head and threads and a part with no threads that is about a half an inch long or so.
  14. Fubeca
    Dec 18, 2002
    2,100
    Denver Area
    Now comes the fun part. LIke 4xcrazy said, the bolt should have a smooth part that goes through the cross shaft into the other side of the carrier. If it broke off past the threads, you should be able to get it with some small picks or magnets (like was mentioned). I once had to drill through the carrier on both sides of the shaft to get access to the pin to get it out. Good luck -- on the bright side the replacement bolt is only a couple bucks when you do get it out!
  15. zach78k5
    May 14, 2000
    406
    where will i find magnets that are that small do you think?
  16. Fubeca
    Dec 18, 2002
    2,100
    Denver Area
    Not sure on the magnets, last one I did I used a small pick, a tiny screwdriver, and a little drill bit.
  17. zach78k5
    May 14, 2000
    406
    well i drilled a little hole and it looks like the shaft somehow rotated. the piece of the bolt on the other side of the shaft is loose as well. I assume it sheared. I should be able to pound the hell out of it until it comes out i guess. I drilled the hole pretty close to the shaft and there is no overhang into the housing. This is my typical luck.
  18. zach78k5
    May 14, 2000
    406
    Well, indeed there was a piece of the bolt stuck. I got it all out (had to drill a little hole) but i still can't get the stupid shaft out. when only one wheel is jacked up and I spin the other wheel, it spins in the housing. So it will move and when I pound on it, it will move about 3mm either direction. What else could be holding this sucker in place?
  19. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Some times there will be a ledge from scoring, you will have to pound it but like mentionned before be carefull.
    Another thing you might encounter depending what gears you have, you might need to grind the corner of one tooth in the ring gear to clear the shaft once it's at the end.
