Help!!! How can I make my motor stay cooler?**UPDATED**
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by RingMaster4x4, May 6, 2002.
  1. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    I have a 427 tall deck w/ 160 thermostats.There is a 4 core radiator and dual elec. fans I can not run a flex fan. Not room for one. The motor runs 200 most of the time just driving down the road at highway speed and 210-220 if you are speeding up and slowing down. Let me know what you think.
    I posted the update at the bottom.
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Re: Help!!! How can I make my motor stay cooler?
    You say you have a 4core, how long has it been in use? May want to get it rodded out and hot tanked. You can also get a higher voulume water pump from Summit. Robertshaw makes a hig volume thermostat also.
    What type of electric fas are they, or a better question may be what CFM are they rated at? Summit also sells a FlexAlite brand M150 BlackMagic fan that is rated at 2800cfm. I would say your motor needs atleast 2800cfm to keep it cool.
    Good luck
  3. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    have you tried running the 180 deg thermo. your 160 may not be staying closed long enough time for your water to cool down in the rad.
    also, reduce the amount of anti freeze in your mixture. 100% water actually keeps the engine cooler than 50/50 ratio. water disipates heat better than antifreeze.
    my 2 cents
    ARQ.
  4. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    my thoughts exactly!! if it flys right through, it wont get to cool down! it seems kinda bakkass'erds, but it be true /forums/images/icons/wink.gif
  5. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    Burt's thoughts are the first ones I had. A 30/70 mix of antifreeze and water will cool the engine more efficiently than a 50/50 mix. Make sure that the cooling system is completely burped of air or it will tend to create local hot spots. Short of that, get rid of the copper/brass radiator and go with an aluminum radiator.
  6. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    I had a 180 in there samething was happen.
  7. 4x4k20
    4x4k20 1/2 ton status
    Mar 17, 2001
    1,699
    williamson ga.30292
    that is the normal temp for a big block to run i had a 454 that would stay up close to 230 all day long while towing it would run at 210 when not loaded big blocks burn more fuel therfore they put out more heat
  8. POFF
    POFF 1/2 ton status
    Aug 13, 2001
    221
    San Diego, CA
    Automatic or manual tranny? If it's an auto is there a cooler in the radiator? Try an external tranny cooler. Make sure you get a good one though. Retarded timing or small fuel jets can make it run hot too. Make sure the radiator cap is good.
  9. 91K5
    91K5 1/2 ton status
    Jul 5, 2000
    185
    Wichita, Kansas
    I have a 402 big block in my car, and it runs about the same temp as well, about 190-210 degrees normally. It's just normal for them to run warmer. You might try adding a external oil cooler if you don't have one already, a lot of heat can be disapated through the oil using these. A buddy of mine with a 454 got one of those aluminum water pumps that flows more evenly, and I think it dropped the temperature a little bit too.
  10. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    My '95 dually came with a external trans cooler, oil cooler, a extra electric fan and a power steering cooler stock. And it runs around 210 when warmed up.
  11. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    Thanks for all the help!! I am going to have the rad. cleaned And more fans after that. I will let you guys know how it goes. Thanks!
  12. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    Ok, Well my 427 still runs 220-230 going down that highway with 180 thermostats. Since I first put up this post I have put in a new Radiator, I put in the 180 thermostats, new dual 13" perma-cool fans ( like Bob K) , and a new water pump. It has improved. I can let the motor idle or drive in town in stop and go trafic all day long with no prob. But try to go down the highway at a steady speed and It will slow go up the longer you drive. /forums/images/icons/confused.gif /forums/images/icons/confused.gif /forums/images/icons/confused.gif
  13. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    I am in the process of replacing my twin electric fans on my BBC (4-Core radiator also!) with a QUALITY pair of Flex-A-Lite ones. The ones I had before were junk....though I didn't have anything to compare to at the time. A buddy of mine came over and was like...."Dude, when are these fans going to turn on?".....I told him that they WERE running!! /forums/images/icons/shocked.gif
    They put out such a small amount of air, they couldn't keep the motor cool. These new ones move about 2500CFM, and when they turn on....you KNOW it!!! (LOUDER!)
    The problem could be something simple too....like lousy fans. Though to be honest, at highway speeds my engine always ran about 180 degrees....it was only around town, or wheeling (less airflow) that the engine would get hot.
  14. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    See my problem is the exact opposite I can cool my motor all day long no problem wheeling or driving around town. For example I drove my Blazer around town for 9 hours nonstop ( I did not even trun off the motor when I went in to a place) a few weeks back with no problems. As far as the fans go I can hear the fans over my motor and the dual 40 series flowmasters. It pulls enough air through the raditor that if you put a blade of grass in front of the grill it will hold it there. /forums/images/icons/grin.gif
  15. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    they also have an additive you put in the radiator that is supposed to cool the engine by 20 degrees.im not sure what it is called,but it cost 25 dollars for the bottle of it.ive talked to a couple of people and they say it works.
  16. jeffro
    jeffro 1/2 ton status
    Jul 2, 2002
    406
    Scurry, TX
    Could ignition timing cause overheating? Could your gears be too tall for the tires you have?
  17. Burt4x4
    6,854
    Antoher thought is that your gage is not reading the temp properly?
    Water Wetter is an additive that is suppose to reduce temps too?
    Good luck
  18. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Are You Sure, that the Fan Shroud is Sealed up around the Radiator, not open at the Bottom, and the Fan Is 1/2 in the Shroud, and 1/2 out of the Shroud?
    On My 454, I found a gap at the lower end of the Shroud, and sealed It up with High Density Foam Rubber.
    At this point even in 95 Degree Temps, in traffic, It still runs Cool at Stop Lights, Moving, Whatever. Don H. /forums/images/icons/cool.gif
  19. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Do you turn your fans off on the freeway? At speed They might be slower than the incoming air and creating turbulance and poor airflow.
  20. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    Well I think that I am closing in on the problem. The other day me and my friend put the tranny cooler back it to the rad. Now my motor run 210 all the time and 220-230 if you are going down the road at 50 MPH. /forums/images/icons/mad.gif Before I could drive 65-70 before it would run that hot. What do yall think?
