Help! How do i put a telescoping driveshaft back together??
Discussion in 'The Garage' started by BowtieRed, Jun 11, 2003.
  1. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    My drishaft came apart when my yoke broke, and now i need to put it back together. it won't slide on easily, and it didn't used to come apart. i slide it on so the splines lined up then hit it a bit with a hammer and now it's semi stuck- do i just keep hitting it harder till it's back on right?
    thanks,
    red
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I believe it should slide in-n-out with ease, the shaft may be bent or the splines could be screwed up somehow? What happened when the yoke broke? How fast were you going?
  3. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    I don't think it just slides in and out because I know that mine won't just pull apart. Maybe theres a snapring in there or something...
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The seal on the end of the female part of the shaft is usually screwed onto the end of the shaft. Unscrew the seal first, drive it onto the male part of the shaft, then the shaft should slip together. However, if the splines got twisted as it came apart, even slightly, then you'll need to have the slip joint replaced. /forums/images/graemlins/frown.gif
  5. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    Did you match up the master slines? They only go together a certain way for balance reasons.
  6. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    idk what i did, but with a little persuation from BFG it finally went on, and slips fine, i drove it, (FINALLY!) and no vibration)
    i unscrewed the seal, that didn't do jack-
    thanks guys,
    red
