Help how do I put it back together??
Discussion in 'The Garage' started by MTBLAZER89, Jun 14, 2003.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    The side gears and the springs.....how do these parts go back together?? Thanks.
    -Brian
  2. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    With the use of a bolt, say 6 1/2" long, two large flat washer's, and a nut. You'll have to push some to get the nut started after that, it'll be easy. Make Sure that the washer's will fit through the bore's in the carrier first, before you try and put it together. /forums/images/graemlins/grin.gif
  3. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    OK so the springs go inbetween the locker body and the side gears then use the long bolt thingy to keep it all from springing apart???
    -Brian
  4. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Yepper's, it will work if the bolt is long enough, even longer but it has to be short enough for the completed locker package to fit in the carrier. /forums/images/graemlins/grin.gif
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The most important part is the little bumpy steel ring that goes in the center of the locker. It's the cam that decides when things should lock or unlock. If it isn't installed correctly, then the truck won't move, as the side gears will unlock any time power is applied to them. /forums/images/graemlins/eek.gif (Some morons at a "professional" diff shop installed mine wrong, after they told me that they "didn't need" to use the shipping bolt to hold the locker together when they took it apart to install a new ring and pinion). /forums/images/graemlins/angryfire.gif It's been a long time, but I think the description of how to index the cam properly was included with the directions that came with the locker.
